Old 05-18-2010, 09:31 PM   #43
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Bryan,
I guess maybe we could title your post "I reject your reality and substitute my own".
What you post still ignores the concept of Internal Resistance of the each individual battery when connected in series or in parallel and offers only a simplified DC view of electricity /electronics. And your post still denies the basic complications one can face if connecting old batteries with new ones or when connecting batteries of differing capacities.
rustyrivet - if your vendor states that you can connect these batteries together, it is because he knows that they are matched electrically enough to work together. And if he says its OK - it is as good as you can get, no?
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 05-19-2010, 08:32 AM   #44
1975 29' Ambassador
Reno , Nevada
I think the ad hominem is inappropriate, uncalled for, in volation of the TOS here, and shows an inclination towards anything but trying to understand either what others are saying or anything about the topic at hand.
Making claims about Truth and about others' ignorance is not a good way to engender learning or forward the stated goals of these forums IMHO.
A key issue here, I think, centers on the assertion that voltage cannot be used to indicate a battery state of charge. As I noted, nearly every website with battery information has a table that shows voltage versus state of charge. The battery status indicators in Airstreams are simple voltage indicators. It is something that anyone off grid for a while can measure for themselves. To call all of these websites and the applications of the information in them as a 'rejection of reality' begs many questions.
The facts are, the reality is: That all of us who charge our RV's when we hook up and head down the road connect dissimilar lead acid batteries in parallel; That lead acid battery charging and state of charge estimation in modern systems is voltage driven; That there are many who parallel lead acid batteries with significant differences and do not suffer as a result; That old batteries express the same voltage changes as new ones, just faster.
For reference see "Sealed Lead Acid Batteries Technical Manual" by PowerSonic for a good rundown on discharge versus voltage. -- "Lead Acid Battery State of Charge versus Voltage" by Richard Perez. Perez has a number of good articles related to this topic in Home Power Magazine that are well worth study. I also suggest doing a bit of research on conductance testing of lead acid battery status and finding one of the student papers on the electrical model for a lead acid battery and considering its behavior in various circumstances.
Note that I do not address any particular individual. I do not make blanket unsupported assertions or allegations. I provide references that can be pursued to help see what I am talking about. And I provide examples of the concepts that we can all use as a reference for the points I am making. These are the sorts of things any 'corrections' to my views need to accommodate for me to give them credence. Just telling me I'm full of it doesn't cut it. I need to know how an alternative point of view fits with these things and does so better than the understanding I have.
I provide plenty of material, citations, and examples to address. I suggest it would be more profitable for all here if they were refuted rather than me.
Old 05-20-2010, 02:59 PM   #45
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
Buttercup, I was not attempting to reject Bryanl's science or impugn his sources. My only reason for commenting was to say there are other sources of information available. When I got my A/S two years ago it only had one series 24 battery, located on the A frame and there was no room for a larger battery. I researched batteries on-line, decided that the Lifeline looked like the best battery, regardless of price. I contacted a local RV Shop (Blue Lake RV) and spoke to Lars. I told him I wanted to add another battery. He determined that, if I used a Lifeline battery, I could put it in an inside compartment and that it would be safe to do so without venting to the outside. He also said the compartment was large enough to accommodate a series 27 battery, which would give me slightly more storage power. I had read articles on line that said you should not mix sizes. To get reassurance that it would be OK, I called Lifeline and spoke to Justin. He said that as long as the batteries were both Lifeline and of the same age (in my case, new) there would be no problem. I had the batteries installed on the basis of those conversations. I figured that Lifeline must have some of those EE types working there, and unless there is a complete disconnect between their engineers and their customer service folks, I should be all right. I did put the inside battery in a sealed battery box and vented it to the outside. As an added precaution, I just switched my converter to a PD 4655. So far, no problems. I will keep you posted if they occur. I make no pretense that I understand electricity: AC or DC jc
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
rustyrivet is offline   Reply With Quote
Old 08-24-2010, 10:07 PM   #46
Malibu , California
Aolani, can you verify which batteries you installed? I am doing the same conversion because my oem interstate batteries stopped holding a charge after about 6 months (2009 Airstream 27FB) probably get better results from a couple of AAA's at this point. My stock battery box is approximately 10" deep and the Lifeline AGM's I am looking at are the GPL-4CT's which are 9.92" tall and with the cables will require an additional 1" of clearance (similar to your mod). You indicated that you put in the GPL-6CT's which are 12.94" tall, which would require about 4" of clearance, was your battery box deeper to start with? I would like to put as big a battery as possible, any clarification will really help.
Just for the record, I think the performance difference between the stock oem batteries vs. the Lifelines sound pretty amazing, I would be stoked to get similar results, regardless of the hair splitting contest that went on in this thread. Thanks.
istoilkovich is offline   Reply With Quote
Old 08-24-2010, 10:12 PM   #47
_
IF u need help visualizing the box mod,
there are several threads WITH PHOTOS of this in post #16 above, so check out those links and pics.
and it's NOT hair splitting.
install HEAVIER/larger batteries and EXPECT more amp/hour reserve and useful capacity.
it's not amazing OR hair splitting, it's simply MORE lead and acid in a bigger box.
ya know how the trial size deodorants don't last as LONG as the family size BIG stick?
same thing same thing...
cheers
2air'
Old 08-24-2010, 10:33 PM   #48
Malibu , California
No, I am clear on the box mod, it's more of a math question, 10" stock battery box + 1" mod = 11" clearance, try to put a 12.94" battery plus cables in an 11" box = doesn't fit. And I think your missing the point on the word 'amazing', when you go from barely getting through the night with your batteries to lasting 3 days, it's amazing. The physical size of the batteries is not drastically different and I realize it's a simple concept that yields the better performance, but sometimes you get excited when something works.
Old 08-24-2010, 11:16 PM   #49
_
not missing anything here.
it's NOT possible that 'barely one night' becomes 3 nights...
not with the change as described.
it's simple amp hour math and the EXTRA WEIGHT give more juice...
but NOT 3 times more juice, THAT would be amazing.
and there is NO PERFORMANCE DIFFERENCE that is not accounted for my MORE lead and acid and water...
heavier=amazing, 2x6v vs 2x12 has got nuttin' 2 do with it...
except the 2x6v WEIGHS 180lbs and the 2x12 weighs 120 lbs.
once again the battery box mods are CLEARLY posted in other threads and with a LOT more credibility.
i do agree that occasionally when MORE money is spent for MORE WEIGHT and something good happens it can seem amazing.
cheer
2air'
Old 08-25-2010, 02:02 AM   #50
richinny's Avatar
2011 34' Classic
a good battery, replacing a bad battery, is always an improvement!
Ricky
Old 08-25-2010, 06:25 AM   #51
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Experience with 6 v batteries
Hi,
Two years ago I made the 6v switch.
Works like a champ.
Battery tales upgrading batteries for boondocking Safari SE - Airstream Forums
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 08-28-2010, 08:06 AM   #52
Aolani's Avatar
2010 25' FB Flying Cloud
Santa Rosa , California
Istoilkovich -
Sorry for the delay replying; was out enjoying Life (smile). Am pretty sure I ended up with the GPL4CT (would have to go check- it's been awhile). They fit into the factory box perfectly from a width/length perspective, but were of course just under 1" taller, as predicted.
My heighth extension modification shown in one of my initial posts was just about 1".
We still love the improved results and have boondocked quite a bit. Even spent two weeks boondocking in the spring up at Burney Falls with moderate sun hitting our solar panels. Used our genset occasionally, mainly for TV and to top off the batteries every few days when no real sun at all (unusually cool/cloudy spring this year here).
The system of better battery performance/capacity + solar worked great. We're happy and pleased we made the investment (we boondock a lot).
Good Luck!
Aolani is offline   Reply With Quote
Old 09-02-2010, 05:16 PM   #53
toddster's Avatar
1967 20' Globetrotter
Campbell , California
So, I'm thinking of getting new batteries for my '67 GlobeTrotter. Should I get 2 12V in parallel or 2 6V in series???
Kidding!!! Please do not respond to that question.
My only observation is that after adopting one form of multiple battery religion, I may have to switch sides due to physical limitations. Isn't life grand. I guess either way, the added capacity of a second battery is something I like to have!!!!. Happy trails my friends, I have REALLY enjoyed reading this discussion.
One side note about energy storage.... Back when I worked as an engineer at Tesla Motors, the Roadster's battery pack was rated at 53kW-hr capacity. How I would love to boondock with that sort of energy in reserve.
toddster is offline   Reply With Quote
Old 04-14-2011, 12:15 PM   #54
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
Good Luck!
Thanks for sharing! We did the a similar upgrade and are experiencing great results. We went with (4) Lifeline 6V's, plus solar and have effectively removed energy management from the list of things to worry about while boondocking.
ostream is offline   Reply With Quote
Old 08-29-2011, 05:15 AM   #55
2011 27 FB International
Leesburg , Virginia
Originally Posted by 2airishuman View Post
with 2 batteries i consider 2x6v as NOT an improvement and with the potential for NO juice
1 can also buy/use one GIANT 12v agm (like the 250LB offering from lifeline) and that's another ok approach.
here.
I dont get this one of your main reasons to avoid 2x6v is reliability/duplicity incase of a single battery failure the other 12v can take over by itself. One big 12v losses this advantege?
2011 int 27fb serenity
2011 f250 CC 6.2L
27fb2freedom is offline   Reply With Quote
Old 08-29-2011, 06:06 AM   #56
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by ostream View Post
....... list of things to worry about while boondocking.
What's to worry when "dock'n"....seems like a waste of time.
Just do it...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
What an amazing service matthews Member Introductions 14 11-11-2006 07:40 PM
Switched to a motorhome! 48-remi Member Introductions 2 02-01-2006 06:46 PM
Heat pump switched on in AC mode Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-22-2005 08:09 PM
