05-23-2011, 04:49 PM
1962 22' Safari
kansas city
, Missouri
Isolator? charge line ?
I need some advice:
how hard is it to add a 12v DC charge line from TV to TT, or is it all ready in the 7 way?
Any recommendations on an isolator, how to's and size, links? diagrams?
locatin?
We have a 02' Doge Ram Diesel it has 2 start batteries
1962 Safri 22ft.
Thanks to all that have helped with our baby.
Indy
05-23-2011, 05:04 PM
Sioux Falls
, South Dakota
7-Way Tester
05-23-2011, 05:13 PM
Corona
Originally Posted by indy
I need some advice:
locatin?
1962 Safri 22ft.
Indy
A charge line is already built into the trailer.
It's a "blue" wire.
05-23-2011, 05:15 PM
1979 23' Safari
1954 29' Liner
Orange
Indy,
The seven wires are:
tail and running lights
right turn/brake
left turn/brake
electric brakes
ground
backup lights
charge line
Bill
I need some advice:
locatin?
1962 Safri 22ft.
Indy
Just my personal opinion
https://billbethsblog.blogspot.com/
05-23-2011, 06:06 PM
2002 25' Safari
Dewey
On my last two TVs the charge line was only active when the key to the TV was on. This prevents the trailer from draining the TV battery when parked.
Richard
05-23-2011, 06:55 PM
2008 27' Classic FB
Burkburnett
If the TV was built with a towing package, it most likely has a battery isolator for the reason previously mentioned. If using a volt meter or test light to verify your charge line, the ignition must be on. On my earlier Mopar, the isolator was a diode block mounted on the firewall. On the current Ford it is a relay located in the engine compartment fuse box. The output from the isolator is often protected with a fuse. All 7-pin trailer connectors should include the charge line. If you don't see 12v at the 7-pin socket with the ignition on, check your TV owner's manual for the location of the relay and fuse.
AIR 47751
05-23-2011, 08:20 PM
1962 22' Safari
kansas city
, Missouri
Thanks for the help all.
will test as stated above.
be safe
Indy
P.S.
The axle is on T.Y. Andy
