Old 03-23-2011, 06:33 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Is this going to burn something up?
I'm working on something out in the yard and I want to use the spook light on the trailer for light, but I need to take the battery out.
Can I take the battery out and just let everything run from the converter to the 12v panel without doing any damage?
Added a pic. The black and red vertical wires on the bottom go to the battery.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-23-2011, 08:02 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sure
I would say you can. The converter is nothing more than a fancy power supply. It really doesn't care what the load is, but it does know the difference between a light bulb and battery. I've had the new inverter in my trailer for month's with no battery and everything is fine. I also have the same converter as yours. I just couldn't see putting a battery in new that would sit for 6 to 8 month's without being used. So I took the old battery out and remove the fuse on the plus side.
Old 03-23-2011, 08:06 PM   #3
DanielB's Avatar
So you have a converter hooked up the the 12v panel with no battery?
It seems like it should be alright, but electricity can be weird.
- Andrew Carnegie
Old 03-23-2011, 08:13 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
I did mine that way all last summer while I worked on it. Battery cables are in separate plastic coffee cans pushed through cross cuts so they don't start touching and making sparks.
Old 03-23-2011, 08:13 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It's Ok
Yes; it is connected to the distribution panel. In the normal way. I just removed the fuse going to the battery, because the cable is just hanging in the battery compartment and I didn't want it to be hot from the converter and maybe come in contact with the skin or frame.
When you run the converter without the battery, the voltage will be a little higher, but it won't hurt anything.
Old 03-23-2011, 08:24 PM   #6
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Yes it will work and not likely hurt anything. The battery does however act as a filter for spikes and lows in the power supply. If you have high or low voltage for long enough it can cause damage.
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Capt. Wilson's 1959 Overlander nmbosa 1954 - 1959 Overlander 309 05-09-2016 01:18 PM
Why trailers burn Jammer Electrical - Systems, Generators, Batteries & Solar 35 05-17-2011 09:05 AM
For those of you with money to burn... blmitch5 Airstream Lifestyle 3 03-21-2011 07:38 AM
