Old 03-25-2015, 12:22 PM   #1
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Is this adequate?
Amazon.com: Blue Sea Systems 5028 ST Blade Fuse Block with Cover: Sports & Outdoors
A friend of mine had this laying around and offered it to me when I told him about my converter change in the Argosy. I am installing a PD 9245.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 03-25-2015, 12:25 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
IF you are talking about using this to distribute 12V power in the trailer, if none of your fuses are larger than 30A, and if the sum of all your fuses is less than 100A (because the batteries can supply more than the converter's 45A) this panel should do nicely. You may wish to place a separate fuse in the line from the 9245 to the battery if the 9245 doesn't have one. I think my 9260 did.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-25-2015, 12:31 PM   #3
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Yes, I am considering using it as my 12v distribution panel from my converter. My main concern is battery hook up as those are heavy wires
Old 03-25-2015, 01:34 PM   #4
Central , Mississippi
I used it's bigger brother several years ago. So far its worked great.
http://www.airforums.com/forums/f109...ml#post1135941
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-25-2015, 01:42 PM   #5
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
HiHo,
Would you happen to have a diagram/drawing of what you connected where? I am 99% sure of what I need to do...it's the 1% that makes me hesitant. Thanks!
Old 03-25-2015, 02:03 PM   #6
I used 5 seperate circuits;
1) to the Airconditioner
2) Street and curb side closet light, bath vent fan, Bath light, rear compartment light, Bedroom ceiling light, rear vent
3) Living area
4) Street side bedroom lamps and power outlet, fridge, avi panel and cubbard lamp
5) Kitchen (water pump also) and spare wire in the ceiling at the foot of the bed.
I probably have a few more things that were added since my notes were made in 2011...
Old 03-25-2015, 03:37 PM   #7
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
1) 12v to the AC?
not understanding that?
I have no AC at the moment but plan to add one.
Old 03-26-2015, 08:17 PM   #8
Originally Posted by mnmhays View Post
1) 12v to the AC?
It was a 'leaning forward' circuit. Some AC's need 12v at the unit.
(I also used it to run the vent fan that was in the hole until I holed back enough skimmed grocery $$$ to buy an AC)
Old 03-26-2015, 09:48 PM   #9
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Ahhh...I see, makes sense now. Last question. It seems that the PD 9245 instructions has a redundant - grounding in the diagram. It shows the negative going to the DC dist. panel but no negativeto hook it to, should I add another ground bar for the battery negative?
Old 03-28-2015, 06:04 PM   #10
I didn't use the grounding side on the fuse block. All of my low current stuff is grounded to the shell and the High draw stuff (chargers?) run back to the battery.
I did cheat a bit and hooked my old 30A charger into one of the fuses to back charge the battery so the charging side of the system was also fused. I also have a small solar charger back-feeding thru a 20A fuse.
Old 03-28-2015, 08:39 PM   #11
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Thanks for the info. I have decided to ground the battery and the - side of the converter to an auxillary set of grounding lugs. I will tie the converter and the battery together at the + input side of the DC distribution panel. I am putting an automotive 30A self resetting circuit breaker between the battery and the DC panel. It's simple once you figure it out I guess. So many different ways to get to where you need no to. Thanks again, I appreciate the advice!
20 amp adequate if not using A/C HeadWest Electrical - Systems, Generators, Batteries & Solar 9 03-24-2013 07:41 PM
Is generator adequate? Clownshoes67 Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-29-2012 07:53 PM
Is Your Air Conditioner Adequate in 100+F Heat? Fly at Night Furnaces, Heaters, Fireplaces & Air Conditioning 49 07-12-2011 04:03 PM
Is this TV adequate to pull my 31' Sovereign? 310astream Tow Vehicles 9 09-02-2009 09:55 PM
Adequate tow vehicle?????? jrporter Tow Vehicles 22 06-24-2008 02:15 PM
