Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 09-19-2009, 08:40 AM   #1
Profile:  1965 22' Safari
Woodstock , New York
Iota 55amp replacement for old univolt
Yesterday I purchased the Iota 55amp q4 (Randy told me this is the best one to buy) to replace the old univolt in my 1965 Safari. I plan to use the existing circuit breaker panel. It looks like the univolt was only 20amps. Am I going overboard as they say with the 55amp purchase? Can the existing circuit bkr panel be used safely? Thanks for any help; my handyman who is quite excellent will be installing the Iota and a new battery.
jtaggart is offline   Reply With Quote
Old 09-19-2009, 09:02 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Most modern converters are 35+ amps. It's kind of like tooling around town with a 500hp car, you don't need to use all the power. Your original panel can be re-used, again, it's only going to use what it needs. Just don't put heavier duty fuses in the panel.
The converter will probably be able to charge the coach battery faster.
(No Longer at Inland RV)
Old 09-20-2009, 08:10 AM   #3
Thumbs up update on wiring Iota converter
I emailed Randy at bestconverters. He suggested looking at the cable between the Univolt panel (the existing one, which I plan to use) and the new battery. It needs to be 8 AWG to carry 55 amps. He said all of the other circuits are fused already.
I hope it isn't too big a job for my handyman, Bruce.
Need to purchase a new battery; I'm thinking an AGM battery. Any suggestions on where to purchase battery? Also plan to install some solar to keep the battery charged and then down the line to keep it charged when I'm dry-camping.
Thanks overlander63 for your input.
1965, converter, iota, safari, univolt
Univolt AND an IOTA on board??? atobols Batteries, Univolts, Converters & Inverters 3 03-23-2009 07:15 PM
Univolt Replacement TShepherd Batteries, Univolts, Converters & Inverters 18 02-17-2008 04:47 PM
Replacement for my Univolt wingfoot321 Batteries, Univolts, Converters & Inverters 15 05-14-2007 10:17 AM
Iota converter mandolindave Electrical - Systems, Generators, Batteries & Solar 2 07-06-2005 10:26 PM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 04:31 PM
