Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 03-23-2008, 05:48 PM
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere, Florida
Inverter Wiring
This is a view near where the dc electric comes in the front of the AS. Where would be a good place to wire in an inverter?
Tom
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Get rid of these ads... register today, it's FREE
Old 03-23-2008, 05:52 PM
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road, Fulltiming
Status: Online
Near where you are going to be using it would be first choice. If you want to have the inverter energize all outlets, a better place may be near the battery or breaker box.
Aluminitis never sleeps...
AIR#2611
Old 03-23-2008, 06:22 PM
69AmbassFl
Profile:  1969 29' Ambassador
orange Park, Florida
I would probably try to wire in as close to the battery as possible. That way you don't have to run lengthy battery cables to it. If you put it in between the battery and the main breaker panel you can power all outlets with it and not have to run excess wiring, as the wiring between the battery(s) and the area that you have pictured may not be heavy enough for the invertor.
Old 03-23-2008, 06:28 PM
henw
Cyclist
henw's Avatar
Windermere, Florida
I'm just going to use the plug outlets on the inverter. The red wires in the photo are positive. The white ones negative. I thought I would just wire it in there. Just wanted to make sure doing such would not cause trouble.
Tom
2007 28' Int CCD.
Old 03-23-2008, 06:29 PM
overlander63
Status: Online
As long as you don't exceed the wire curreent capacity, there should be o problem.
AIR#2611
Old 03-23-2008, 06:50 PM
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove, California
When I installed the inverter on our Caravel, I put it close to the batteries. I went to Pep Boys and got a pair of jumper cables that had nice multistrand copper wire and cheap connection handles, which I cut off. It is important to use heavy copper cable between the batteries and the inverter. The run should be as short as possible. Small wire or long runs can cause inverter failure. The longer the run, the larger the cable needed. Your inverter instructions should have a size/length guide. I use a short extension cord with a switched six outlet box, placed in a central area where I can plug in the TV, Dish box, DVD player, laptop or other small draw items.
My inverter system is separate from the 110v trailer wiring. In our case, there was no reason to try to integrate the two. I plug items into the inverter outlet when boondocking, plug into the trailer outlets when hooked up.
Very simple, and works well for us.
Old 03-23-2008, 06:52 PM
henw
Cyclist
henw's Avatar
Windermere, Florida
Thanks. I feel better about plundging ahead. The longer red cable, I believe, is the positive directly from the battery. The white wires originate where the black negative cable from the battery terminates. I suspect they are beefy enough.
Tom
2007 28' Int CCD.
Old 03-23-2008, 07:46 PM
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL, Hood River, OR
Tom
Tom,
I would run a dedicated set of cables of appropriate AWG (#2 or better) directly from your batteries to your inverter. Doing this will eliminate the future possibility of any electrial problems within your DC circuitry. Every motorhome that I work on with an inverter is wired like this.
Lew Farber - contact
Certified Master RV Tech
ON THE ROAD mid-May !!!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-23-2008, 07:59 PM
Jim Foster
Jim Foster
Jim Foster's Avatar
Originally Posted by lewster
Tom,
Don't even think about doing it any other way....
Old 03-23-2008, 08:38 PM
Motoman
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside, California
Tom,
I also agree with Lewster if you are installing a fairly large inverter, say a 600 watt true sine wave inverter like Airstream installs as an option. However you haven't told us what size you are installing. If you are talking about one of the cheaper 300 or 400 watt modified sine wave inverters with a cigarette lighter plug or cables to connect to a battery you can probably use a smaller wire and possibly connect to the DC power buss inside the trailer.
Give us some more info.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Old 03-24-2008, 03:47 AM
henw
Cyclist
henw's Avatar
Windermere, Florida
I'm planning in installing a 1000W pure sine inverter. To run the TV, DVD, computer etc.
If I wire it directly to the batteries ( which are outside on tongue ), will the cables to the inverter fit through the small hole entering the trailer with the dc electrical bundle?
2007 28' Int CCD.
Old 03-24-2008, 01:55 PM
Motoman
Motoman's Avatar
1960 18' "Footer"
Definitely requires separate cables straight from the battery. I would suggest that you use "0" or "ought" gauge wire from the battery to the inverter.
I am installing the 600 watt inverter that Airstream uses and I am bringing the wire through a plastic exterior electrical box attached and sealed to the aluminum plate in the spare tire area behind the tongue where there is no belly pan or insulation. I am using liquid tight connectors for each wire into the box. I haven't installed it yet but could send you a picture of the box with connectors installed and the area where it will come through the floor. I'll try to get the pictures this afternoon.
SNU #157
FCU #004
Old 03-25-2008, 05:34 PM
Motoman
Motoman's Avatar
1960 18' "Footer"
I couldn't find a nice weather-proof boot to use to run the wires through the floor in so I decided to use an exterior plastic electrical box with liquid-tite compression connectors to feed my DC cables in through the floor to the inverter (see the first two photos). The box will be attached and sealed to the floor near the spare tire and an opening cut through the back of the electrical box and floor to run the cables through. You can also se the liquid-tite connectors where the individual positive and negative wires will feed into the box coming from the battery.
I also included a picture of the area near the floor penetration for the existing wiring where the box will be mounted to the underside. i will have to make sure that the location doesn't interfere with removing and installing the spare tire carrier.
ID:	56965  Click image for larger version
SNU #157
FCU #004
Old 03-25-2008, 06:35 PM
henw
Cyclist
henw's Avatar
Windermere, Florida
Very nice idea Don.
Tom
2007 28' Int CCD.
vB code is On
Pingbacks are On
Inverter wiring Safari Tim Electrical - Systems, Generators, Batteries & Solar 30 01-11-2007 09:08 PM
Planning new wiring with inverter Jacob D. Electrical - Systems, Generators, Batteries & Solar 8 12-05-2006 09:06 AM
What is an INVERTER woodedareas Electrical - Systems, Generators, Batteries & Solar 7 11-28-2006 11:37 AM
inverter mlmarch Mechanics Corner - Engines, Transmission & More... 2 11-15-2004 10:36 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
