Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 03-26-2008, 12:29 PM   #1
crdouger
crdouger's Avatar
Profile:  1960 22' Safari
Rockford , Michigan
battery charger question
I know the best way to maintain batteries is to have a nice 3 stage converter/charger maintianing your batteries. And I've also been recommended to have 20-25A charging capacity per battery. I have two 125ah batteries. I'm only going to camp several weekends per year. Can I just use my 6A car battery charger and charge it up before I go on a vacation and then use a battery minder to maintain them in my garage between trips? I know it will take longer to charge, but if I'm only using it for occasional weekends, can I get away with this?
Doug
crdouger is offline   Reply With Quote
Old 03-26-2008, 12:49 PM   #2
Leipper
Profile:
With the battery minder for storage and an allowance for a bit of time for charging, you should be in good shape.
The reason for the 20 amps of charging per 100 AH of battery is for rapid charging without so much as to damage the battery.
The key concepts are to keep the battery at full charge as much as possible and to use some sort of desulfation process when it is sitting. That generally leads to best battery life.
Bryan
Leipper is offline   Reply With Quote
Old 03-29-2008, 09:51 AM   #3
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
I see no problem with that Doug. My only concern would be if the 6 amp charger has the capability to raise the voltage above 14 to ensure a full charge. Many modern chargers do however many older chargers do not.
Nothing wrong with maintaining them with a batteryminder or tender. Like Bryan said, make sure you take advantage of the desulfation feature if it has one.
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 05:52 PM
HF Battery Charger dmaiden Batteries, Univolts, Converters & Inverters 10 11-03-2006 11:33 AM
Battery Charger luckydc Batteries, Univolts, Converters & Inverters 10 02-07-2006 08:04 PM
Solar Battery Charger Cstar Generators & Solar Power 2 01-04-2005 11:59 AM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
