The drawers are easy enough to remove and put back. There is a latch on each side on the bottom. Open the drawer, squeeze the latch and then move the slide back in about 1/2 inch to disengage it from the drawer. Then just lift the drawer out.
use a flashlight and see what is mounted under the floor.
places to look are the drawers under the sink, oven, microwave and fridge.
In the 30', the inverter is under the microwave. The ZipDee controller is under the sink.
About the only thing the manual showed the position of was the water pump (under the fridge) and the Alde (under the front dinette seat. Everything else I found by just taking an afternoon and removing drawers to see what was where.
The hardest was under the stove/oven. Since we opted for the oven, there is no drawer under it, just a door with a 4" deep shelf. When I ran water/power cross body for the RO unit, I had to pull the oven to gain access to the cross body channel. It was obviously designed to do that. I removed 6 screws and all of the connections (electrical & gas) had long enough cables to remove the oven and set it on the floor out of the way while I worked under it.
The trailer was well thought out in that respect. it turns out that the converter is easier to access from the oven area than it is from the closet area.
The fridge obviously has a space behind it where you have to pull the fridge to access it. I'm quite positive there is a bunch of electrical equipment (having to do with the czone control) back in there because I can't find it anywhere else. I just haven't needed to access that area yet.
I'm getting read to install an EMS unit and some Ham radio equipment and may need to access that area just to run cables, but I'll wait until I need to.
