Old 11-12-2016, 08:52 PM   #1
2011 28' Flying Cloud
Orillia , Ontario
Inverter to shunt
Does any one have any photo's of there inverter to shunt wiring. I want to run in a new set of cables from my batteries to converter and to the shunt to measure power draw on battery.
Thanks George
Rust is offline   Reply With Quote
Old 11-12-2016, 11:49 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I did this install 3 weeks ago.... sorry no photos trailer is in storage. Prior to installing the shunt I had a 4 gauge cable from the batt to the negative bus in the trailer, and a second 2 gauge cable from the batt to my inverter...
I simply attached 2 ring terminals to those negative cables from the battery and terminated both those negative leads to the shunt (batt side)
Then I made 2 new cables (2 ga and 4 ga) and Terminated the 2 ga into the inverter and the 4ga into the neg bus for the trailer.
Hope that helps. It was an easy install for me ...
wulfraat is online now   Reply With Quote
Old 03-20-2018, 07:53 AM   #3
2008 23' Safari SE
Houston , Texas
I'm wanting to add the battery monitor as well. here's a picture of my wiring with solar controller. the battery negative terminates at the negative bus. the red and black wires you see in the foreground are the inventer wires that goes through the floor out to the battery.
Do i cut the inverter black wire, install rings and attach to the load side of the shunt? does a wire then still need to go to the battery or is this a sufficient ground?
its obvious i'm not an electrician.
Name:	controller wiringbest.jpg
Rocket53 is offline   Reply With Quote
making a shunt? batt Batteries, Univolts, Converters & Inverters 20 03-12-2012 11:43 AM
Univolt shunt ALí UM- MONEY Batteries, Univolts, Converters & Inverters 3 12-20-2010 09:29 AM
Fresh water shunt installed Excella CM Fresh Water Systems 5 01-19-2010 01:13 PM
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-17-2009 12:40 AM
TriMetric 2020/2021 shunt - 100 or 500 amp? ostream Electrical - Systems, Generators, Batteries & Solar 3 11-06-2008 03:37 PM
