Old 07-08-2011, 09:01 AM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Inverter sizing
Just to run the (gas/120) refrigerator on the 120 when in tow, I did the math. When plugged into 120 the heater in the refr draws 2.4 amps. IxE=P 2.4x120=288. so i bought an 800 watt inverter. I thought over kill but the price was right.
Why then does it scream to much power draw? What am I missing here?
GeocamperAS is offline   Reply With Quote
Old 07-08-2011, 09:12 AM   #2
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Some cheap inverters use Surge power as their sales rating and not RMS
Also your amp draw was based on sine wave coming off the grid
What your inverter may be making is square wave. A resistive load like a element will run on square but draw more
Darkspeed is offline   Reply With Quote
Old 07-08-2011, 09:12 AM   #3
Darkspeed's Avatar
1972 31' Sovereign
What inverter? Specs?
Old 07-08-2011, 09:24 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Oftentimes inverters where the price is right can't deliver anything close to their advertised output.
Old 07-08-2011, 10:09 AM   #5
Darkspeed's Avatar
1972 31' Sovereign
Any chance you bought a 50hz inverter???
Old 07-08-2011, 04:04 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most inverters are only 80% to 85% efficient and many aren't rated even that high.
Have you determined how many amps you are actually drawing from the battery when running the fridge on the inverter?
If you figure 85% efficiency the 2.4 amps when on shore power looks like
1.22 x 2.4 x 120 volts = 352 watts. So on the 12 volt side it is 352 / 12 = 29.3 amp draw on the battery.
If for example you were trying to run a 240 watt heating element with a 12 volt battery, you would require a continuous 20 amp draw at 100% efficiency. Running the fridge on 12 volt electric (battery) is really inefficient.
Old 07-08-2011, 05:27 PM   #7
Darkspeed's Avatar
1972 31' Sovereign
Especially heating a resistive load to drive an absorption cycle system designed for propane. A good off grid dc fridge around 7cf should draw a real 55w for comparison
Old 07-20-2011, 07:57 AM   #8
1974 Argosy 28
Images: 37
Solved the problem
The inverter was large enough. It was my wire size between the battery and the inverter that was to small.
The fridge now works off the 120v through the inverter when in tow or just off the battery. Battery only I watched the 12.89vdc drain down to 12.24vdc in 10 hours. Now I know if I had to I could get through the night.
Old 07-20-2011, 08:25 AM   #9
Darkspeed's Avatar
1972 31' Sovereign
Well that's cool! Glad you got it working
Costco CPE 2000W Inverter Generator Tom Bray Generators & Solar Power 10 05-30-2011 05:13 AM
Inverter guidance ostream Batteries, Univolts, Converters & Inverters 2 04-21-2011 08:20 PM
Dometic Inverter Generator nm1oqrz Generators & Solar Power 2 02-27-2011 08:12 AM
Need advice on inverter replacement for Paralax Nightwatch Electrical - Systems, Generators, Batteries & Solar 1 02-13-2011 01:04 PM
