Old 10-26-2007, 05:48 PM   #15
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
gene
i work for the power company and would like to see honda stand up to their claim!
it would be hard for me to believe that a reciprocating one kva gen set would be better than what most utilites are expected to deliver.
all of the circuit breakers in our substations are set to trip open if the frequency varies +or- 1/4 of a hertz.
either you get the good stuff or you get nothing!
john
you call them ferrets, i call them weasels.
Old 10-27-2007, 01:40 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
How clean is clean?
Originally Posted by john hd
gene
john
John,
I'd like to plug into the power company out in the boonies, but the extension cord would be too long.
I think I saw the Honda claim with graphs and other things I didn't understand on their website. People run TV's and other electronics with generator/inverters a lot. I suppose laptops too. Does the converter clean up bad 120 and give "clean" 12 v so a small inverter could be plugged into the 12 v plug? I suppose the question is whether the Yamaha & Hondas are clean enough.
Gene
Old 10-27-2007, 03:20 PM   #17
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
no free lunch...
everybody probably knows this but thought I'd remind just in case we've forgotten. most inverters (dc->ac converters) are really inefficient. They dissipate most of the lost power in heat energy. Depending on the model and electronics (and temperature) efficiency can go from a best case of 70% down to 40%. That's why high amp devices will kill lead acid batteries realy quick
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 10-28-2007, 10:07 AM   #18
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I think its more than that
Xantrex Technology Inc. - Recreational Vehicles - Prosine 1000 and 1800 - 120 VAC/60 Hz - Specifications
They are showing up to 90% efficiency.
I know for a fact the outback units for home use are around 90% as well.
Michelle TAC MT-0
Sarah, Snowball
Old 10-28-2007, 11:22 AM   #19
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Gene,
Check this out. Disclaimer: I haven't tried it myself. I also think there's someone else making something like this.
Modified sine wave (really stair-stepped square wave) inverters can be hard on any inductive load, especially little wall-warts, by causing excessive heat.
Maurice
Old 10-28-2007, 02:12 PM   #20
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
EU2000i Real Clean Power
gene
john
John
I had one of our Meter Relay guys do a check on my EU2000i, it tested out at 0.01% harmonic distortion at 60.001Hz, a perfect sine-wave. We were shocked at these figures, real real good. We did not load test it, did'nt have the load bank at the time. I would use one of these generators anytime.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 10-28-2007, 04:26 PM   #21
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
gary
i would be interested to see what it would do on the hot box.
no doubt they are a quality unit, otherwise they would not be such big sellers.
john
Old 10-28-2007, 04:34 PM   #22
1976 Argosy 24
Tempe , Arizona
standing corrected
obviously i was in err.... the ones you refer to are much more technologically advanced than the ones I had in mind. My experience is with the radioshack units such as
RadioShack.com - Power & Batteries: Car power: Power inverters: Whistler PI-3000W 3000W Power Inverter
many apologies
Donna & Mike
WBCCI #2417
Old 07-20-2008, 10:37 PM   #23
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
I am having trouble using a modified sine wave inverter to run the laptop. I plug it in (I have two different units that behave the same way) to the Airstream 12v socket and the inverters squeal a low votage warning, even if the coach batteries are full. If I plug the same inverter into the truck power socket they work fine. Any ideas?
rp709 is offline   Reply With Quote
Old 07-20-2008, 11:03 PM   #24
_
Originally Posted by rp709 View Post
Any ideas?
hi rp'...
the 12 v outlet in question might REALLY have low voltage....
-have u measured the outlet voltage with a multimeter gizmo?
-do all of the 12v outlets inside the stream get this result?
-have u tried the 12v outlets while plugged into shore power?
-have u tried CLEANING the 12v outlets?
-pulled the outlet and check the wiring/connections?
a little corrosion can cause issues...
cheers
2air'
Old 07-20-2008, 11:07 PM   #25
lewster's Avatar
Naples, FL , Hood River, OR
rp,
Check the voltage of your coach batteries independently with a quality VOM and see what the reading is. They might be showing low voltage under load, which means that they could be bad.
You could also charge them completely with a separate battery charger (with the negative terminal disconnected) and then load test them to see how they perform. This will tell you what their true condition is. I just don't trust battery level indicators.
Old 07-21-2008, 05:05 AM   #26
2001 34' Limited
The State of , Ohio
First, check the amperage or wattage requirement of the laptop power adapter. For example, if it is rated for 1.2A@120VAC, it can draw as much as 1.2 x 12 = 14 amps from your trailer batteries. If it is rated at 120W@120VAC, it can draw as much as 120/10 = 12 amps from your batteries. This multiplier and divisor in the previous formulas are what they are because the power adapter isn't 100% efficient.
Note that in both examples above, the amp draw from the batteries exceeds the 8 amp maximum of the cigarette lighter outlet on the Winegard anteanna plate and may cause it to melt and/or burn.
That amount of current will also cause a voltage drop, both in the wire supplied with the inverter, and in the wire running from the outlet to the trailer batteries. Although Airstream typically uses 12 AWG wire, this voltage drop can cause you to get a low-voltage warning on the inverter if the wire run from batteries to outlet is very long. It is generally best to wire an inverter to the downstream side of the big fuse coming from one of the batteries with as absolutely short, and as heavy as necessary, wire, fusing that wire adequately.
A voltage drop will not occur when you're using a meter to measure the voltage in the outlet without the inverter plugged into it. What you may see there is a voltage drop caused by other lights or appliances on the same circuit as the outlet.
Hope this helps,
Maurice
Inverter Question henw Batteries, Univolts, Converters & Inverters 3 05-20-2007 07:56 PM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-19-2007 11:23 PM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 09:25 PM
Inverter installation question Streamin 65 Batteries, Univolts, Converters & Inverters 13 06-07-2006 08:28 PM
Inverter question Dbraw Electrical - Systems, Generators, Batteries & Solar 7 10-26-2004 11:25 AM
