Old 05-20-2007, 04:46 PM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Inverter Question
The parrallax converter/charger in my AS has a flip open front panel. Sitting next to the fuses are positive and negative lugs from the batteries.
They are of a size that could be easily gripped by the jumper cable type connectors that come with some inverters. Any thoughts on using this route for periodic inverter hookup?
henw is offline   Reply With Quote
Old 05-20-2007, 05:25 PM   #2
Images: 59
I wouldn't even think of it. Too high a risk of shorting to the converter chassis or other wiring.
Better to wire it in permanent. At the least, run a positive wire from the converter to a remote, easily accessed lug, so you can attach the clamps without having a shower of sparks. Also add a fuse or breaker.
Old 05-20-2007, 05:40 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Clamp on leads are attended-use only, never let them out of your sight. The grip is so little surface area that high resistance connection is likely and you can/will melt a lot of plastic fast if the inverter gets a work out... fused direct wire, don't trust small inverters internal fusing; put a fast acting inline fuse in it...
Old 05-20-2007, 07:56 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
The ONLY place I would connect an inverter is directly to the battery posts or to a set of dedicated lugs that come directly from the battery posts. Calculate the maximum amp draw from the inverter spec sheet and add a fuse to the positive lead for circuit protection. Anything else is a possible disaster in the making, unless you're using one of those small types that plug in to a 12VDC power socket (like a cigarette lighter plug). They are rated for 15 amps MAX. and won't power much.
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
