Old 08-05-2008, 05:51 AM   #1
1969 27' Overlander
austin , Texas
inverter or converter?
Hello everyone,
I'm new to all of this and in my usual fashion dove in head first.I bought my first and only AS which is a 69 overlander a few months ago and am living in it fulltime.My lights,when I woke up this morning,would "cycle" brighter then dimmer.I was told I probably needed a new inverter but after reading some threads I'm wondering if I might need a converter instead.I am hooked to shore power and do not have a battery hooked up since my original manual said I didn't need one if connected that way.All my outlets were are working just fine(at least when I left for work this morning).So thank you in advance for any help given and I'm sure this wont be the last you hear of me!
slapshift is offline   Reply With Quote
Old 08-05-2008, 06:34 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Yes, it's a converter you want. Intellipower is good. 3 stage WFCO is better.
Try BestConverter - Converters, Inverters, Electrical Supplies, Electronics
5 meter Langford Nahanni
Old 08-05-2008, 07:51 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Yes, it is a CONVERTER that you want. A converter takes 110 volt power and makes it 12 volt for your interior light and other 12 function. An INVERTER takes 12 volt power and makes it 110 volt.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-06-2008, 01:47 PM   #4
Aluminum Addict
Gastonia , North Carolina
A battery in the system might be a good idea. The battery acts as a filter in the system and can smooth out the highs and lows and make for a more controlled voltage in the 12 volt range. The Univolt has been notorious for boiling the battery dry and there are better convertors on the market today than the old factory installed Univolt. Regards...
---AIR # 17817---
DJ
Heirstreamer is offline   Reply With Quote
Old 08-07-2008, 10:53 AM   #5
1969 27' Overlander
austin , Texas
Thank you all so much for your help.I'm clear on what I need!
Old 08-12-2008, 12:56 PM   #6
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Just a quick thought -- I experienced similar behavior of lights dimming when there was a slight short in the wiring to the hot water heater direct to ground resulting in the circuit breaker on the DC side kicking on and off. So ... just make sure there ISN'T a problem of some sort causing the cycling on and off.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Alternatives to Factory Converter & Inverter shovelbum Batteries, Univolts, Converters & Inverters 17 04-04-2008 11:14 PM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-19-2007 11:23 PM
Converter / Inverter? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 2 12-10-2006 09:57 AM
where is the converter/inverter thing? jcdasa Electrical - Systems, Generators, Batteries & Solar 13 08-28-2005 10:10 AM
inverter mlmarch Mechanics Corner - Engines, Transmission & More... 2 11-15-2004 10:36 AM
