Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-20-2009, 08:13 AM   #1
big_john's Avatar
Profile:  1986 25' Sovereign
Gainesville , Georgia
Airstream Registry
Inverter - On or Off?
Taking my generator and multi meter up to do some investigating today, but I'm not an electrician. My brother is and he gave me some instruction. In the meantime, I'm really not sure if my batteries are being charged. Here is a pic of the inverter on/off switch. Not real intuitive...is it ON if you can see ON, or is it ON with the rocker arm covering ON (and leaving OFF visible)?
big_john is offline   Reply With Quote
Old 11-20-2009, 08:17 AM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 64
Airstream Registry
It is hard to say, it depends on how the cover was installed. This looks like something that a PO installed. Testing it with a meter would be the only way to know for sure.
BTW, I think you meant to say converter.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-20-2009, 08:36 AM   #3
Profile:  , Minnesota
Images: 59
Airstream Registry
Normally those come with the switch installed so the handle points at the condition. As shown, it would be off.
You can however take the screws out and turn the cover over so that it shows the opposite. Like Richard says it's possible the PO switched the switch so it could be "on". Need to test it with a meter.
I would suggest if it is "on" with the handle as shown, that you change it back to the correct "off" condition.
Old 11-20-2009, 11:19 AM   #4
Profile:  1972 29' Ambassador
Harrah , Oklahoma
Agreed, else somebody will be in for a shock.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 11-20-2009, 11:50 AM   #5
Wingeezer's Avatar
Profile:  2005 30' Classic
Burlington , Ontario
Interesting the different viewpoints! I would have said that in teh pic, it is definitely in the "Off" position!
We could take bets, and then Big_John can settle it when he gets his multimeter out!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-20-2009, 01:03 PM   #6
big_john's Avatar
Airstream Registry
So I took my multi meter up just a while ago and lugged the generator up as well. My converter is a relatively new IntelliPower 9200 series. Here is what I determined:
1. With the switch in its current state and no AC power applied the meter read 12.5 VDC on both batteries.
2. With the trailer hooked up to the 120 VAC generator the voltage across both batteries read 0.0 VDC.
....so, I think the answer is now clear...the position shown in the picture above is OFF.
3. I flipped the switch so the rocker arm was pointing to ON and the voltage across both batteries, while plugged into 120 VAC generator, was +14.5 VDC.
My battery indicator (Poor, Fair, Good) on the info panel soon went from Poor to Good. Mystery solved
Old 11-20-2009, 01:07 PM   #7
Phoenix , Arizona
Images: 64
Airstream Registry
I don't understand why the batteries would ever read 0.
Richard
Old 11-20-2009, 02:16 PM   #8
Images: 59
Airstream Registry
Originally Posted by Wingeezer View Post
. . . We could take bets, and then Big_John can settle it when he gets his multimeter out!
Brian.
Pay up, sucka!
Old 11-20-2009, 06:00 PM   #9
big_john's Avatar
Airstream Registry
I can only think that it would read 0 because:
a. the converter was "off" hence any potential potential (ha) was "short circuited" by the converter as it was not ON.
b. coupled with a) above, the AS is designed so that when AC power is provided, all DC power is stopped.
c. the reason there is a switch on the converter is to allow charging while connected to AC power, hence when the switch was thrown we got 14+ volts for charging.
Again, I'm not an electrician so I am merely making an educated guess (I am an engieer, but a chemical flavored one).
What do you all think?
Old 11-20-2009, 06:07 PM   #10
Wingeezer's Avatar
Pay up, sucka!
That's why when we go to casinos I just look over my wife's shoulder!
Brian
2005 Classic 30'
Old 11-20-2009, 06:15 PM   #11
Profile:  1978 31' Sovereign
Madison , Mississippi
Unless the batteries were completely dead you should always be able to read some voltage at the battery posts regardless of AC or converter state.
Birdwell57 is offline   Reply With Quote
Old 11-20-2009, 08:39 PM   #12
Phoenix , Arizona
Images: 64
Airstream Registry
We know that the batteries have a charge from the measurement in step #1
We know that the switch is on in step #3 because of the higher voltage reading at the batteries.
In step #2 AC power is applied to the trailer, but the converter is not powered up. The readings should be the same as in step #1.
I can not think of anything that would cause the batteries to read zero volts. If something is pulling them down to nothing, it would be a dead short. You would smell something smoking at that point.
Could you verify that the voltage in step #2 again. Check each battery individually and then check them in parallel. If the line between the two batteries is some how controlled by the switch, you might read zero if you only tested the batteries in parallel. If that line is switched, it would keep the batteries from charging but would allow the converter to keep powering the 12 volt items in the trailer. This is the only solution I can think of. Since it only seems to work with power on the trailer, I would think that the switch would be controlling a relay to open and close the connection. This is a stretch, but who knows...
Richard
Old 11-21-2009, 07:49 AM   #13
big_john's Avatar
Airstream Registry
ok. we're going back up today and I will recheck and even take some pictures because this is kinda fun.
from what I recall from yesterday I know I read BOTH batteries at 0 vdc after shore power was attached....?
I'll post some pics later this afternoon.
Old 11-21-2009, 03:14 PM   #14
big_john's Avatar
Airstream Registry
Didn't make it to the trailer today...going tomorrow after church. Stay tuned.
Inverter magwa Land Yacht/Legacy Motorhomes 35 10-17-2009 12:55 PM
Do I have an inverter? cmreumund Batteries, Univolts, Converters & Inverters 4 02-01-2009 08:10 AM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-20-2007 12:23 AM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 10:25 PM
inverter mlmarch Mechanics Corner - Engines, Transmission & More... 2 11-15-2004 11:36 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
