Old 07-17-2019, 01:12 PM   #1
2018 30' Flying Cloud
Anchorage , Alaska
Inverter neutral
I will be installing a Multiplus 2000 and am thinking about the wiring. I have a 50 A main panel and plan to disconnect one leg, run it to the multiplus and refeed that leg with the output of the multiplus.
My question is on the neutral. The multiplus manual has you run separate neutrals from the shore power to the multiplus and from the multiplus to the load center. I can't think of a reason why a single neutral wouldn't suffice. The advantage to me is I would only need to run a single 6/3w/G instead of two cables.
I plan to fish the cable through the floor where the DC load center/Converter cable runs, so only having to get a single cable in there would be nice. Is there something I'm not thinking of?
AKNate is offline   Reply With Quote
Old 07-18-2019, 01:04 PM   #2
Anchorage , Alaska
Here's a diagram of what I want to do, just to make it a little clearer.
Name:	Multiplus wiring.png
Old 07-18-2019, 02:21 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
What you are doing is similar, but not identical, to the split phase case in the manual. I would talk to the manufacturer about your specific application.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
back up light/safety neutral switch on turbo 350 turfclubroad Mechanics Corner - Engines, Transmission & More... 2 01-22-2010 07:45 AM
Location of transmission neutral switch? str8strm Mechanics Corner - Engines, Transmission & More... 7 08-30-2009 06:21 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 03:27 PM
Open neutral diagnosis? markdoane Lights - Interior & Exterior 3 08-07-2009 07:33 PM
