Old 10-17-2014, 05:55 PM   #1
1971 31' Sovereign
wills point , Texas
inverter.location
please help me to find the location and operation of my inverter in my 31' 1971 airstream thank you.
airstream 74 is offline   Reply With Quote
Old 10-17-2014, 06:03 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, first are you sure you have one? I was told there was one in my trailer, but there is not.
MICHAEL
Old 10-17-2014, 06:21 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Are you sure you're not looking for the converter? The converter charges your batteries and provides 12VDC to the trailer when on shore power.
An inverter provides 120VAC from your batteries when off-grid, but the quality units can also charge your batteries when on shore power.
Pretty sure you don't have the latter.
Old 10-18-2014, 06:13 AM   #4
1971 31' Sovereign
wills point , Texas
Thank you for your response, I may be confused.
is there a converter in my 1971 airstream? If so my I know the location, and the action for repair or replacement please.
thank you for your help neighbors I am trying to understand , never had an airstream before have a great day!
Old 10-18-2014, 06:26 AM   #5
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Unless a previous owner removed it you will have a converter. I'm not a vintage guy so I can't help on location. There are many threads on AF regarding converters, but the short answer is yes you should consider a replacement. New multi stage converters are much better for your batteries. A good resource is bestconverter.com.
Landrum is offline   Reply With Quote
Old 10-18-2014, 06:55 AM   #6
The new converters do not have a fuse panel.
Remove the fuse panel from the current Univolt (the converter) and install it with a new Univolt.
There are only three connections with the replacement.
Positive, negative and ground.
Using the old fuse panel, will also save you more than a hundred dollars.
Old 10-18-2014, 07:07 AM   #7
A person must be careful when purchasing a "inverter", the device that changes 12 volts DC to 120 volts AC.
For AC equipment to operate properly, the AC, which is a sine wave, must be very good.
Cheapy inverters do not put out a very good sine wave, which makes it very inefficient, and could ruin some equipment.
The sine wave, the plus and minus happens 60 times per second. The actual peak AC voltage for 120 volts AC is 170 volts. 120 X 1.414.
Old 10-18-2014, 07:26 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'm pretty sure the Univolt is in the curbside storage compartment (or closet), under the end of the bathtub.
Inverter location paullovern Sprinter and B-van Forum 34 07-07-2014 02:38 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
hummmmm from the inverter/battery charger? Anna Electrical - Systems, Generators, Batteries & Solar 5 11-25-2002 06:46 AM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
