Old 08-19-2015, 10:03 AM   #1
2013 31' Classic
Simpsonville , South Carolina
Inverter issue
Hi,
I'm new to the Airstream world, having recently purchased a 2013 31 Classic with solar and 600w inverter packages. The trailer was a consignment, and although they made significant money on the sale the dealer has been no help so far. The inverter panel does not appear to be working. Whether I'm plugged in, or not, I am unable to get any response to the on/off "button". Looking under the sofa I see green and red lights on the inverter itself. I have tried the switch on the inverter, and the lights go off/on but nothing on the panel. I cannot locate a manual in the package of paperwork I received, so am unable to check proper operation. The Airstream owners manual is extremely brief in discussing the inverter.
I'm looking for any help that might be available. The dealer tells me they have called the factory, and were told it is either on or off. I'm not sure what that means in regard to the switch working or not.
Streamin' Eagle is offline   Reply With Quote
Old 08-19-2015, 11:20 AM   #2
richw46's Avatar
Lexington , Kentucky
What model do you have?
Are the lights on the inverter blinking?
Have you tried plugging into one of the outlets to see if it's hot?
I have the WF-600T, here's information from my manual:
There are 3 LED indicators on the front panel:
Input Level
Load Level
Power status - If this light is blinking on the inverter, what is the speed of the flash?
On the inverter and on the back of the panel there are RJ-11 connectors that look like telephone lines. Are both plugged in?
Is the inverter plugged into a 110vac connection? If so, this is a pass through function and the inverter won't run, it just passes through the AC voltage to its plugs. (Ignition lockout)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-19-2015, 11:20 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If you can figure out the name of the inverter you can go to their website and down load a manual.
MICHAEL
Old 08-19-2015, 11:26 AM   #4
1974 Argosy 20
Kooskia , Idaho
Here is a link to the manual for the WFCO 1000 watt inverter, which is similar to t he now discontinued 600 watt one you have.
http://wfcoelectronics.com/wp-conten...00-Manual1.pdf
If you google WFCO you will find their web site, and technical support pnone number for more information, and possibly a link to the exact manual you need for your 600 watt unit.
Old 08-19-2015, 11:59 AM   #5
richw46's Avatar
Something else occurred to me just now. There is a toggle switch on the front of the inverter. It should be down for 'remote'. If it's up it's in the power on mode and will simply provide power to the outlets, bypassing your remote button.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-19-2015, 12:59 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by ArlinV View Post
Hi,
In the standard Airstream factory inverter installation, the inverter will power a limited number of outlets that only work on the inverter. When shipped from the factory these outlets are clearly marked. In other words, not all the AC outlets in the trailer will have power when you are using the inverter. Have you identified the so-called "inverter outlets" and tried them to see if they are energized?
Bob Martel
WBCCI# 5766
Old 08-19-2015, 05:47 PM   #7
2013 31' Classic
Input Level
Load Level
Rich,
Thanks for your response. I need to check the things you mention when I get back to it in a couple of weeks. I am storing it at our RV lot 100 miles from home.
I believe the green light was steady, and the red was blinking, but not sure now. I did not see a third indicator, but it was difficult viewing things under the couch.
I did not test the inverter outlets when power was unplugged, but I know they were powered when plugged in. We did watch some TV and video, and I connected the satellite to one of the outlets.
Now that you mention the RJ-11 connections I can see that could impact the control. I'm sure that is how the panel connects to the box itself.
Are you indicating that the inverter has a 110v cable attached that can be plugged in? I must be interpreting you incorrectly.
I had the trailer unplugged for a couple of hours while I trimmed a tree I was concerned might fall on it. During that time the solar meter dropped from 100% to less than 20%. I neglected to check the systems monitor to see what it showed though.
Old 08-19-2015, 05:50 PM   #8
2013 31' Classic
Michael,
Thanks. I had hoped to do that, but it was very difficult to read anything even with the drawer removed for access. I'll try again when I get back up to the trailer.
Old 08-19-2015, 06:07 PM   #9
2013 31' Classic
Idroba,
Thank you for the link. Not the most robust manual I've ever see. I cannot locate one for the 600w, so I'll call them to see what I can get.
Old 08-19-2015, 06:10 PM   #10
2013 31' Classic
Bob,
I did, in fact, identify the inverter powered outlets. I did not test them because I presumed (probably another mistake) that the inverter was not functioning because the panel did not display anything. I will test further.
Thank you.
Old 08-19-2015, 06:15 PM   #11
2013 31' Classic
When I switched the toggle down there were no lights on on the inverter. I did not think to test the panel then. Are you indicating that the panel does not "work" when the switch is up? Do the inverter lights come on if the switch is down and you turn it on from the panel? I can find no direction in the manual for the 1000w inverter that covers this.
Old 08-19-2015, 08:01 PM   #12
richinny's Avatar
2011 34' Classic
i found the manual at BestConverter - Converters, Inverters, Electrical Supplies, Electronics THANKS YOU RANDY!
http://www.bestconverter.com/assets/...f600manual.pdf
Ricky
Old 08-19-2015, 08:13 PM   #13
richw46's Avatar
Rich,
[snip, snip]
The inverter is normally off. Some inverters (my 600 does) have a 110 male plug that you can connect to a 110vac source so when you're on shore power even the inverter plugs are hot. Disconnect from shore power and press the button on the control panel and the inverter comes on, making the inverter plugs hot with 110vac.
The switch on the front in the up position will turn the inverter on (bypasses the remote). In the middle position it turns it off. In the down position it allows the remote to be used (inverter is off until the remote button is pressed). Put yours in the down position and then go to the switch on the wall (mine's in the kitchen) and press the soft touch button, it should light up.
I scanned some pages from my manual but it's not uploading. I'll try tomorrow, I know they're having some attachment issues.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-19-2015, 08:23 PM   #14
richw46's Avatar
Let's try this way
-Rich
Rich & Yvonne
2004 4Runner SE
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Installing an Inverter Krazykraut General Motorhome Topics 4 12-08-2002 11:22 AM
hummmmm from the inverter/battery charger? Anna Electrical - Systems, Generators, Batteries & Solar 5 11-25-2002 06:46 AM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
