Old 12-07-2012, 09:39 PM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Inverter Install
Where is the best place to install an inverter? I bought the Xantrex 1000 watt and have a 25' Airstream with a sofa. (if that matters). The directions state to use a zero gauge wire and no longer than 6'. My battery connections are under the sofa below the front window. Any ideas would be appreciated.
Old 12-07-2012, 10:57 PM   #2
Electrical rules apply, not opinions.
Not many choices when you can only go 6 feet.
Old 12-07-2012, 11:07 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Mount the inverter as close to the battery as possible. The 1000 watt inverter will draw in excess of 90 amps from the battery(s) when under full load. The wire should be sized for the total load.
If you have access to welding cable or locomotive cable. This type of cable is high current capable, flexible and easy to work with.
Old 12-08-2012, 09:54 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Mine is mounted under the couch right next to the converter.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 12-19-2012, 01:28 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
A reminder to also fuse (or circuit breaker) the new install... both on the DC side as well as AC ...
