Old 04-20-2011, 11:23 AM   #1
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
Inverter guidance
Looking to get some help regarding inverters. A couple of year ago, I upgraded the converter in my '06 CCD to the Xantrex XADC-80 to charge my (4) Lifeline GPL-4CT's. I also have a "starter" AM Solar AM-100/HPV-22B solar setup which I'm adding an additional 200w to bring my to 300w of solar charging.
I'd like to also add an inverter for complete off-the-grid flexibility. The question is, is it better to add the same make (i.e. Xantrex) inverter, can I go with another brand (i.e. Magnum), or is it best to dump the XADC-80 and get an integrated converter/inverter (i.e. Magnum MS2000-U)?
ostream is offline   Reply With Quote
Old 04-20-2011, 12:53 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
No real reason to match brands.
The integrated converter-chargers reuse a bunch of components so they are somewhat lighter and cheaper than two separate pieces of hardware. They can't charge and invert at the same time, which is a problem if you have really dirty incoming power and want to run off the inverter while charging -- though few people do this. On the other hand the switching logic prevents you from doing that by accident and draining your batteries without realizing it.
I have concluded that large inverters aren't worth it because the only large load I really use is the air conditioning and it isn't practical to have that large a battery string. Your situation may be different I guess. I have a 175 watt inverter I use rarely.
Old 04-21-2011, 09:20 PM   #3
New Borockton , Alabama
Images: 21
I would recommend a separate inverter simply because the are so much less money and if either the charger or inverter section should ever fail, you're not out both units.
If I didn't have a converter already, I might consider a combo but they are very expensive and heavy. We move a lot of Xantrex Freedom 458s to the field and to dealers for large motorhomes but haven't seen very many in Airstreams. I like the Xantrex Prowatt SW a lot but like mentioned, there is no reason to stay with Xantrex, they just make pretty good stuff.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 11:11 PM
Dometic Inverter Generator nm1oqrz Generators & Solar Power 2 02-27-2011 09:12 AM
Need advice on inverter replacement for Paralax Nightwatch Electrical - Systems, Generators, Batteries & Solar 1 02-13-2011 02:04 PM
Value guidance on a 1984 Sovereign fun2bethad Trailer Values 3 02-08-2011 06:50 PM
