Old 02-07-2010, 02:38 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Inverter Grounding Question for Electricians
I just purchased a Xantrex Freedom 10 Inverter-Charger. Unlike the Magnatek battery charger-converter presently in my Sovereign, the Freedom 10 calls for a ground connection. What's the best way to tap into the ground? There's a ground wire running to the 110v fuse panel. Can I safely connect to that?
Thanks in advance.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-07-2010, 03:03 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Thanks in advance.
Even though electrically they are the same potential I would not connect there.
I would connect directly to the Trailer frame close to the convertor.
2004 Excursion 4x4
Old 02-07-2010, 03:12 PM   #3
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
On the instruction manual it says to ground to the AC wiring. If the AC wiring is grounded to the chassis you can go to the body or frame.
arodriguez60 is offline   Reply With Quote
Old 02-07-2010, 03:37 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks guys, appreciate the quick response. I assume the easiest way to tap into the ground is through a nearby rib, correct?
1958 Overlander
4CU 1st VP
Old 02-07-2010, 03:41 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That's what I did when I replaced my converter.
Richard
azflycaster is online now   Reply With Quote
Old 02-07-2010, 03:43 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Cool, thanks Richard.
1958 Overlander
4CU 1st VP
Old 02-07-2010, 07:39 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
On my 73 27' they created a primary ground tied to the main chassis steel ladder frame about 18-inches from where the cord went into the black tank area, the household style solid wire ran back to that point from the air conditioning - outlet receptacles (converter) disconnect panel that had the rubber cord ran to.. .
. ..so the Main AC ground was hidden except when viewed from the black tank area, loose and corroded, practically useless - I suggest you renew the hardware there and use an anti-corrosion compound, I have a tiny tube of "NO-OX-ID A Special" that's made for iron as well as copper and aluminum and is conductive (therefor do not use it anywhere it might creep across and complete a circuit, just grounds or buss bars etc..
Wabbiteer is online now   Reply With Quote
LCD TV, inverter question... lvcat2004 Batteries, Univolts, Converters & Inverters 26 12-15-2011 08:32 AM
Inverter question Gene Batteries, Univolts, Converters & Inverters 25 07-21-2008 05:05 AM
ELECTRICIANS (or others knowledgeable) please help. SmokelessJoe Electrical - Systems, Generators, Batteries & Solar 42 08-26-2007 05:23 PM
Inverter Question henw Batteries, Univolts, Converters & Inverters 3 05-20-2007 07:56 PM
Inverter question Dbraw Electrical - Systems, Generators, Batteries & Solar 7 10-26-2004 11:25 AM
