New here ish. We have a 2015 23D international. I used the battery disconnect button when I stored it a couple of weeks ago. Now when I go to turn the switch back on it won't work? I'm sure it's something stupid. But apparently I can figure it out... Any help?
Your batteries may be dead. Even though you put the switch into the Store position, the LPG Leak Monitor continues to run. I would check the voltage at the batteries to see if they are discharged. If so, you may need an external charger to put enough energy into the batteries to activate the Use / Store switch.
So, hate when there is no end to a story... Batteries were totally dead.. Over a year old and the unit has been in FL the whole time. Florida is hell on batteries. Anyway. We purchased the unit only 45 days ago and I totally did not expect the batteries to crap out. In the end Orlando RV took care of me as I hope they will with the bed when technically they did not have to (used unit). I even told them that I totally get I have nothing coming contractually. It is a customer service thing. The service writer and GM were helpful and gracious.
