Old 05-27-2017, 06:56 AM   #15
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My 2013 interstates are still doing fine, along with the original converter..just saying
Old 05-27-2017, 08:34 AM   #16
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Well, I will be buying a decent battery charger this time. I am personally familiar with IOTA, since that's what's on our sailboat, but would appreciate any advice on the easiest three stage charger/converter to replace the thing Airstream supplied.
Since I also have to buy a couple of new batteries, I would also appreciate recommendations on what will fit into the little battery box behind the propane tanks. I modified it two years ago by cutting the sheet metal so I could go to the next size up on the batteries. I am limited in height, though, so I can't go with taller batteries.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-27-2017, 09:16 AM   #17
aftermath's Avatar
Spokane , Washington
I have an IOTA 55. It was installed by the local Airstream dealer soon after I purchased the trailer. It was an easy fit for them and I have been pleased with the performance. I am going on 6 years on the current batteries and will be looking at replacements probably this year.
aftermath is online now   Reply With Quote
Old 05-27-2017, 09:33 AM   #18
lewster's Avatar
Naples, FL , Hood River, OR
2 of the Lifeline GPL-27T 12VDC @100 amp/hours each will fit easily if you rotate them 90 to the trailer center axis and will give you a total battery capacity of 200 amp/hours. Also, the Progressive Dynamics PD-4655 is a direct replacement for your Parallax OEM unit...right down to the screw mounts that hold on the faceplate of the power center.
While any converter is not an IDEAL battery charging system for many reasons, the PD-4655 will certainly do an adequate job.
Old 05-27-2017, 03:33 PM   #19
one of those
Gringo's Avatar
Thanks, Lewster. I've been looking into it, and apparently no Lifeline dealers anywhere around here. They list a Batteries and Bulbs place here as a dealer, but they don't seem to carry them. Not even listed on their website.
So, the main game in this town is definitely Interstate. I have two of their deep cycle 27's which are less than two years old. Deader'n Dillingers Dick, too. I'll just buy two more and a proper converter and pay more attention next winter. I'll totally disconnect them from the trailer and put one of the little solar 12 volt chargers on them. I would think that would trickle them okay, especially if I leave them hooked up in parallel but disconnected from anything else. Plenty sunlight here in the winter ( northern Colorado)
The Progressive Dynamics C/C looks good. I'll be ordering one of those this week. I am also okay with IOTA's just installed two on our catamaran last year. But the Progressive Dynamics is a direct replacement for the single stage thing in the Airstream, saving me a lot of fabrication and refuddlement issues. That makes that decision easy.
Thanks for the help.
Old 05-27-2017, 03:49 PM   #20
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Why not just order online and have them shipped to your door in a matter of days? No need to settle for local selection....
amazon.com
batteryguys.com
BatteryStuff.com
sepbatteries.com
etc.
wulfraat is offline   Reply With Quote
Old 05-27-2017, 05:27 PM   #21
one of those
Gringo's Avatar
amazon.com
batteryguys.com
BatteryStuff.com
sepbatteries.com
etc.
Good idea, except for Amazon. I stopped using Amazon couple years ago. You cannot specify shipping carrier you want with Amazon and it caused me a lot of grief as we move around a lot. If I want to pick something up at the nearest Fed Ex office, for example, I've had Amazon ship via UPS or USPS. Whoops, sorry. Didn't mean to get off on my anti amazon rant...
And I don't exactly have a "door" to ship them to, at the moment. and need them day after tomorrow.
Old 05-27-2017, 06:23 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Last Oct I put the trailer in storage, batteries fully charged, put the switch in Store mode.
Last week I went to check on the trailer. Batteries sitting there at 9.5 volts. Got to be a better way.
Seven months and the batteries ran down? That's not unusual. Even in store mode the LP detector is on.
On my last Airstream the Interstates lasted 7 years, this one is on four and still fine. In storage, I connect a "smart" charger to the batteries.
2012 Dodge Durango Hemi/AWD
Old 05-28-2017, 07:47 AM   #23
one of those
Gringo's Avatar
I'd love to be able to connect a charger over the winter, but it's not really an option in the open storage lot. Solar might be a way to go next season, I'm looking into that.
And I will definitely disconnect the batteries from the trailer circuit completely this time around. I'm planning to buy another set of Interstate 27s this time around. This set lasted two summers, and one winter. Maybe with a better charger, disconnecting from trailer, and a solar top up I'll have better luck.
And if I could just walk into a store Monday morning and buy a set of the Lifelines, I would.
Thanks to everyone for the info and suggestions.
Old 06-09-2017, 08:37 PM   #24
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
depending on where you live I bet Randy at bestconverter.com can get you lifeline batteries in a few days.
in deciding on waiting a few days to get lifeline agm or interstate do you self a favor and go lifeline or if cost is an issue get Trojan or costco golf cart batteries seem to get a good review around here.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 06-14-2017, 07:35 PM   #25
2014 27' Flying Cloud
Wenatchee , Washington
Originally Posted by lewster View Post
Sorry for the rambling but I deal with this situation every day and the primary culprit that I have found over the last 17 years in the RV business is the quality of both the batteries AND the charging systems. Yes, some have success with Interstate batteries with careful monitoring and charging, but there are far better systems that work well with much less human input!
As always....YMMV!!!
I joined this forum to learn more about our Airstream. I appreciate your input (and will upgrade our batteries and charging system in the future).
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
BATTERIES. 2 NEW Interstate Batteries kapt59 Airstream Classifieds 0 01-19-2017 08:00 PM
NOOB - Brand new trailer and dead batteries Seinbelld Batteries, Univolts, Converters & Inverters 45 03-28-2016 11:50 AM
Brand new Lifeline batteries--best way to give them a long life? BrianKrueger Sprinter and B-van Forum 13 09-22-2015 08:12 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
