Old 02-17-2010, 10:33 AM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Interference in new Radio
My 8 track has never worked and I finally purchased a new JVC KD-S15, CD Receiver. The Radio is probably middle to low-end piece of equipment. I installed it this past weekend and, of course, everything did not go perfectly. I am powering the A/S with a Honda EU2000i Inverter Generator. When I hooked the radio up I used the original wiring for the Power, Ground, Antenna, and Speakers.
I turned the Radio on and the Display started flashing. In the mean time the temperature in the A/S stopped thematically as normal. When the furnace stopped, the display on the radio stopped flashing and I could barely hear 1 or 2 radio stations. I thought it might be the original antennas contacts being dirty/corroded, and cleaned them up Ė no difference. The next thing I did was to take 2 test leads and connected them from the radio leads directly to the Fuse Panel Ė no difference. Next I brought the 12-volt battery in from the garage and hooked it up directly to the radio. It worked beautifully!
Before I tried the battery I never checked to see if the CD or my I-pod worked. They performed well when the battery was powering it.
After it was running smoothly I found that 3 of the 4 speakers worked. When I touched the wires to the 4th one ( street side rear) I got a loud buzzing. I left it disconnected.
Iíve come to the conclusion that Iím getting some sort of interference from the Generator or Univolt. I donít know if Iím right and if I am, how do I deal with it? Iím not an electrician so if you have an idea, please speak the language of the verbally challenged.
Stone Ridge is offline   Reply With Quote
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Interference in new Radio Stone Ridge Audio, Video & TV 1 02-15-2010 05:15 PM
Electrical & Radio Interference Questions Ganglin Lights - Interior & Exterior 3 07-19-2009 08:48 AM
Sony MEX-R5 head unit causing WiFi interference silverback Audio, Video & TV 1 05-24-2009 01:24 PM
Hitch Interference Camp-Dog Hitches, Couplers & Balls 14 12-13-2004 03:56 PM
