Old 05-28-2010, 02:39 PM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
The trickle charger has it charged most of the way up. We have a 2 hour drive, I assume the battery will get some charging from the van along the way.
Stephanie
Old 05-28-2010, 11:07 PM   #16
New Borockton , Alabama
Images: 21
Let us know how it goes. The alternator will charge your batteries too. 9 volts is not going to cut it though while on shore power. Something is wrong with your converter for sure. Check and see if its in the 2 year warranty.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 05-29-2010, 07:32 AM   #17
Ottawa , ON
Stef,
From what I've read here on the forums, I really wouldn't expect the current through the umbilical to charge up a battery to any great extent on a two-hour drive...
IIRC it only gives a marginal charge to the TT.
I'm sure others will correct me if I'm wrong, though
Old 06-02-2010, 04:35 PM   #18
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
The trickle charger had the battery charged up before we left. When we got there we were frugal with our lights and water pump usage, and only used the furnace at night, set very low, and threw an extra blanket on. We didn't run out of juice. I didn't think we could get three nights of running the furnace without being plugged in, so that was really good.
I've got a call in to see if I can get my converter serviced and how much that will cost. Otherwise I'm going to have to start shopping for a new one.
Stephanie
Old 06-02-2010, 07:42 PM   #19
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
oldie but a goodie
stef, I have the original A/S charger out of my 85-it was working fine when I replaced with what's in there now. if you are interested, drop me a pm
ol' bill
wmarsha is offline   Reply With Quote
Old 06-02-2010, 09:15 PM   #20
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks, Bill, but I think I'll go for something a little newer. I want to make sure whatever I get doesn't fry my expensive AGM battery.
Stephanie
Intellipower hookup 63air Batteries, Univolts, Converters & Inverters 10 01-30-2010 08:09 AM
univolt to intellipower towmommy Batteries, Univolts, Converters & Inverters 21 07-01-2009 06:35 AM
intellipower 9200 jpancini Batteries, Univolts, Converters & Inverters 6 09-06-2008 01:28 PM
Intellipower converter minuet7.3 Batteries, Univolts, Converters & Inverters 6 08-18-2008 07:12 AM
Intellipower Ground(s) Over59 Electrical - Systems, Generators, Batteries & Solar 15 06-16-2005 09:22 PM
