Old 08-13-2008, 10:01 PM   #1
1979 Argosy Minuet 7.3 Metre
Thonotosassa , Florida
Intellipower converter
My intellipower converter seems to be working intermitantly. At times I have 12 volt power and all of the accessories work, but periodically it shuts off, drains the battery and no lights or accessories. How do I troubleshoot it? It is a 45 amp unit about 1 and 1/2 years old. Thanks Curt
minuet7.3 is offline   Reply With Quote
Old 08-13-2008, 10:23 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hey Curt,
The Prog Dyn Intellipower converter chargers have a protective system that shuts off before overheating. This could be due to the following:
An intermittant short in the trailers DC wiring or battery wiring causing an overheat condition, and the possibility of a drained battery. The question here is why the house fuse for dc wouldn't blow first.
The second scenario is a defective battery causing overheating of the charger, prompting a shutdown.
Or, the PD9145 is defective.
To trouble shoot, I would disconnect the battery and observe the converter, see if it still shuts off. If yes, come back...and post your findings. If no, then the battery might be the culprit.
Uwe
www.area63productions.com
Old 08-17-2008, 04:01 PM   #3
1965 Safari Twin 22'
1965 22' Safari
Sammamish , Washington
64 Safari converter
Does anyone know what size converter I would need and what brand is good?
Thanks John
sammamishsafari is offline   Reply With Quote
Old 08-17-2008, 04:20 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Thanks John
Suggest you contact Randy at bestconverter.com
He is a member here and can give you good advice.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 08-17-2008, 04:23 PM   #5
richinny's Avatar
2011 34' Classic
Randy at www.bestconverter.co
Ricky
Old 08-17-2008, 05:59 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Thanks John
John,
I believe that for Safari, a converter/charger that puts out about 40 to 45 A is appropriate.
With this you can charge up to 2 batteries, and at the same time supply 12V to the house for fans, lights etc.
Intelli-power converters with their charge wizard module have served me well over the years.I recently purchased a Xantrex 60A unit for a client project. So far, the 60A Xantrex with fuse panel is the nicest made converter/charger that I have seen. But as the other posters suggest, ask Randy for the latest and greatest.
The more capacity you buy in a charger, converter, the cooler it will run and the more headroom you have for charging and simultaneously using 12V in the house.
If you want a mild upgrade, go with a 40A unit. For a full bore 12V redo, go with a 60A.
Uwe
Old 08-18-2008, 07:12 AM   #7
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
converter
I purchased a 45 amp WFCO from Randy a couple of years ago. I have found the convert works flawlessly. Although if i were doing it today I would purchase the 55 amp or larger. I find that with two incadesant lights on in the trailer the fan for the converter is not on. When we turn on a third incadesant light the fan turns on. The fan is noticable throughout the trailer. Our 30ft classic has more incadesant lights than it should. This of course is another issue and someday I will change these lights to led when the technology is appropriate.
Go with the larger unit....
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Installing a new intellipower converter 45 amps toastie Electrical - Systems, Generators, Batteries & Solar 18 06-01-2013 03:54 PM
Parallax to Intellipower TIMEMACHINE Batteries, Univolts, Converters & Inverters 25 01-08-2008 03:29 PM
Intellipower wiring Safari64 Electrical - Systems, Generators, Batteries & Solar 7 09-23-2006 11:32 PM
Intellipower Ground(s) Over59 Electrical - Systems, Generators, Batteries & Solar 15 06-16-2005 09:22 PM
Intellipower wiring? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 16 04-23-2005 12:06 PM
