Old 11-24-2008, 10:25 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Thumbs up Inteli-Power 4560?
Has anyone tried or seen the new Inteli-Power 4560, all-in-one electrical system?
Check it out here:
New Inteli-Power 4560
Looks to be a good solution to consolidate space. We are thinking of using this in our 25' Spartan renovation and put it in the Original "Medicine Cabinet" that was near the rear entry door.
Looks like a good Chrismas Present
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-24-2008, 11:50 AM   #2
1976 24' Argosy 24
Milford , New Jersey
balrgn, Just got done installing the 9260 in our Argosy 24, I didn't have room for the all in one unit which is the 4560, so I install a seperate fuse panel. I can tell you that it is fantastic after living with the old Uni Volt. Just for fun, I can turn on every light in the trailer and run the furnace, and the battery still charges right up. The lights are brighter as well and the battery comes up to full charge much faster. I hard wired a Volt Minder into the fuse panel, but if I had the money i would have invested in a true battery monitoring system. I would say if you have the room for the panel and all, you will not be disappointed. George.
Gkiesel is offline   Reply With Quote
Old 11-24-2008, 12:28 PM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I'll tell you what... I sure could use this. I am suspicious of the charger/load center in our newly aquired 345LE. Radio's hum, doesn't seem to follow D.C. load well. In fact, I am not sure it works well at all, I can't turn it off with the button (but I hear something click every other bush of the button). I love our Intellipower in our trailer - this seems like it would be perfect for the MOHO as well. Hmmm - it just went on my wish list.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-27-2008, 09:08 AM   #4
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Would this be a good unit to start with on a new layout? I have no wiring and I'm about to start laying out wire, outlets, batteries, etc. What else would I need? Thanks and Happy Thanksgiving!
1956Safari is offline   Reply With Quote
Old 11-27-2008, 10:09 AM   #5
Images: 59
Just a couple of thoughts:
1. This is a 50a 120/240v breaker panel. Call Steve and see if they have or will soon have a 30a 120v version. Not that you can't use a 50a panel, but a 30a might be smaller.
2. I really like the "fuse blown" lights on the 12v panel. I have the same panel, but as a separate item, not integrated into the converter.
3. Other items you need will be an inverter, a battery disconnect switch, some 12V circuit breakers for the high flow circuits like the power jack, and fuses for the main battery cables.
Old 11-27-2008, 03:31 PM   #6
Over59's Avatar
Putnam , Connecticut
Images: 37
Andre check your mail...
Over59 is offline   Reply With Quote
Old 11-29-2008, 11:50 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
Looks like a good unit, however those of us with the DC panel in the front, and the AC panel in the real, it won't work!
Newer rigs with wiring designed to use this system are a mixed blessing, but an improvement, I guess...
Having all systems together makes for more wires in a 'tighter' area, but done right, can be an improvement.
I just shake my head when I see new SOB's with their all-in-one distribution center mounted on a panel down at floor level!!! What are those designers thinking about...I wonder it they ever had the chance to have to work on one of those units, while they're laying on the floor!!!
Design the frickin' power distrubution panel to be mounted at shoulder height so it can be easily acessed by the user! Thank you very much...
Ray & Pat; Morada, CA
Old 11-29-2008, 03:33 PM   #8
Images: 59
I agree with Mexray 100%. I mounted both the 120vac and 12VDC panels in an overhead cabinet, and ran a pair of #6 cables to the battery and converter mounted near the floor.
It should work if you mount the whole shebang in the medicine cabinet and run a cable to the batteries.
Old 12-01-2008, 08:08 AM   #9
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
"Looks like a good unit, however those of us with the DC panel in the front, and the AC panel in the rear, it won't work!"
I would like install the Inteli-Power 9200 in my 1976 31' and replace the old fuse panel with a new 12V fuse box such as the one available at Vintage trailer supply.
12V RV Fuse Box.
The fuse panel and converter are located behind the stove with access through a small sliding door. How difficult of project is this.
Don
adonh is offline   Reply With Quote
Old 12-01-2008, 08:59 AM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I'll be ordering mine by the tonight!
$25 gift certificate if you order by the end of today!!!
Vintage Trailer supply
I'm in a good position, no interior!
It will be nice to position it where you can get to it with out standing on your head
www.balrgn.com
Old 12-10-2008, 10:22 AM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
New power panel came in. Will be nice to have all the electric in one spot, not where you have to be a contortionist to access!
It was on back order only for a couple days!
Easy part is ordering it tho!
www.balrgn.com
Old 12-10-2008, 11:38 AM   #12
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
What else is needed once this is added to your layout? Will you be adding an inverter? What kind of wire would you suggest getting for both the 12v and the 110? Thanks...I'm about to pull the trigger on one as well and just now planning out the wiring diagram. J
Old 12-10-2008, 11:48 AM   #13
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Not certain on the wire size DC yet. I need to take measurements on the length. AC I will be going with 12ga through out.
Here is an interesting site..
American Wire Gauge table and AWG Electrical Current Load Limits
Not sure about an inverter, but good thing to think about at this stage. We have not decided if we will be using this rig for boondocking..
Just ordered a set of custom fabricated Font windows (3).
This took a chunk out of the budget!
www.balrgn.com
Old 12-10-2008, 02:29 PM   #14
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
It's here!
Santa came early for Rosie!
Still need to lay out walls , so I'm a ways from installing.
Looks like it will suit really well. I have to rethink where it will go as it Will not fit in that cabinet I had planned on.
Go here to read the facts.. Vintage Trailer Supply - Vintage travel trailer parts and supplies!
ID:	72476   Click image for larger version
www.balrgn.com
Inteli-power clearance/ventilation 63air Batteries, Univolts, Converters & Inverters 0 01-28-2010 08:12 PM
Inteli power or Xantrex RandyG Electrical - Systems, Generators, Batteries & Solar 2 06-10-2008 07:43 AM
Inteli-Power 30/40/50/60????? 05ModPod Electrical - Systems, Generators, Batteries & Solar 1 02-05-2005 11:40 AM
Univolt +/- Inteli-Power = ? krowsea Electrical - Systems, Generators, Batteries & Solar 4 11-14-2004 10:24 AM
Inteli Power 9100 Bryanhu Electrical - Systems, Generators, Batteries & Solar 4 04-12-2004 04:27 AM
