Old 03-24-2013, 06:08 PM   #15
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I want to do the same (run my blender). My Oster blender, according to what's printed on the bottom, is rated to 450 watts max. AM Solar recommended the SureSine 300 inverter. It's a super high efficiency 300 watt pure sine wave inverter that is rated to hold a surge of 600 continuous watts for 10 minutes. When off, it draws just 25mA, which is almost nothing. I was impressed and may well buy this inverter.
kscherzi is offline   Reply With Quote
Old 05-16-2013, 09:24 AM   #16
2013 16' Sport
Chicago , Illinois
R2DTube, did you ever install your inverter to run your blender et al?
We are newbies...we just got our 16' Sport! And are now trying to learn about it. One of the moments of dismay was figuring out that I wouldn't be able to run my blender while dry camping....without an inverter. So we are just now working on getting one (1500 watts continuous) and installing it. Any words of wisdom or experience would be appreciated.
Bliss & Richard
TheBean is offline   Reply With Quote
Old 05-16-2013, 11:36 AM   #17
R2DTube's Avatar
2007 16' Bambi
West Hollywood , California
Images: 11
No, I haven't done it yet. I've been on the east coast again, away from home and all things trailer. I'm heading back home to the west coast next week, and then I'll get back to my trailer projects.
I've got a fairly easy and inexpensive plan cooked up for the inverter. I got all kinds of advice about this project, everything from really expensive to really cheap, and I've decided to go the not-too-expensive route. I couldn't justify spending a ton of dough just to run a blender.
Here's what I'm going to do. I'll use a cheapy 750 watt inverter from Harbor Freight:
12V Power Inverter - 1500 Watts Max
I'm going to create a new 12 volt outlet inside the trailer using this:
Trolling Motor Connector Kit - 8-Gauge | Bass Pro Shops
I'll replace the alligator clips on the inverter with one set of the quick-connects in this trolling motor kit, and then I'll create a new outlet with that nice and clean, 1 1/2 inch diameter round hole plug and the other set of quick-connects. Is that making sense? The wires will connect to the batteries on the tongue and come up through the bottom of the trailer into the compartment under the street-side dinette seat. That's where other wiring comes into the trailer, specifically the umbilical, which I recently replaced and found that it wasn't hard to do at all. These new 8-gauge wires will follow that same route. I should also mention that I'm planning to install an in-line fuse holder near the batteries, which will hold a 40 amp fuse. Then I'll cut a very small, clean hole in the base of the street side dinette seat and install that round hole adapter. Nice and clean. Then whenever I want to use the inverter, I'll just plug it into the new outlet and away we go. I've already tested this inverter with our blender and it works just fine. The blender is maybe an Osterizer I think, 600 watts as I recall.
I had originally thought I'd permanently install an inverter, but it was getting to be too expensive and too complicated for me to do myself, so I've come up with this as a simple and affordable compromise.
R2DTube is offline   Reply With Quote
Old 05-16-2013, 11:40 AM   #18
R2DTube's Avatar
2007 16' Bambi
Images: 11
Another alternative is to get one of these hand-crank blenders, which we have and like a lot, but I'm old and lazy and my arm gets tired!
GSI Vortex Blender |Kitchen Accessories | BackcountryGear.com
Old 05-16-2013, 11:44 AM   #19
R2DTube's Avatar
2007 16' Bambi
Images: 11
Bliss & Richard
I forgot to say...
Congratulations!! Welcome to the family!!
Old 05-17-2013, 06:01 PM   #20
2013 16' Sport
Chicago , Illinois
Thanks, R2DTube! For the Welcome. The quick reply. And the referral to the hand-crank blender. LOL. Not only do I use my blender for smoothies, but I also make almond milk, nut butters, mayo, etc...my arm would fall off! My husband also wants a toaster. I have combed the forum and the internet and learned a lot about inverters. I'll show your plan to my husband (the mechanic/handi-man in the family) and let you know what we decide.
Thanks again,
Bliss
