Old 09-15-2015, 04:42 PM   #81
2015 30' International
FREDERICK , Maryland
That is what I thought. They called me while I was on the road. By the time I got home and called Best Converter, the Service Dept. was closed. I sent them an email and asked them to call me tomorrow. A bit disappointing as they are one of the major Airstream dealerships in the nation.
Doc Foster is offline   Reply With Quote
Old 09-15-2015, 09:06 PM   #82
lewster's Avatar
Naples, FL , Hood River, OR
While you definitely can use the PD 4655, it is an easier swap with the PD 9260, which is a deck mount unit. You (they) would also need to secure the DC fuse block as well.
Definitely NOT rocket science, but your dealer might not be capable of thinking just a bit outside the box on this one.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-22-2017, 10:36 AM   #83
Ed Brownfield's Avatar
2015 28' Flying Cloud
Charlottesville , Virginia
I own a 2015 Flying Cloud. I am not going to attempt to replace the converter myself. I purchased a new converter from Amazon.com and plan to take it to an Airstream dealer for installation. Can you tell me how long it should take to install the converter? I want to make sure that I am not being overcharged.
Bald Eagle
28 Ft. Flying Cloud
2015 GMC Diesel
Charlottesville, VA
Ed Brownfield is offline   Reply With Quote
Old 10-22-2017, 11:57 AM   #84
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Installing a 4-stage converter/charger in your new Airstream
If you canít trust them to treat you fairly for this work, I suggest you go elsewhere. Have they done this upgrade before? I bet they have. Maybe have them quote you the numbers of hours in advance and decide whether you think thatís reasonable.
Rocinante is our 2014 International Signature 27FB
Old 10-22-2017, 12:01 PM   #85
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
In my 2014 the electrical hookups would take an experienced technition no more than 30 min, including time to drink his coffee.
Took me maybe 2 hours because I used a cutoff wheel to pull the old converter from the electrical box and I repurposed the box for the new converter so I could use it to mount the 12v fuses where they were originally.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 10-22-2017, 04:07 PM   #86
Msmoto's Avatar
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
As the originator of this thread, I cannot remember the exact time to install, but the fact I had to fabricate some stuff, it definitely took some time. Also, doing anything for the first time...lots of preparation... lots and lots of preparation and thinking through each step carefully. "Measure twice, saw once"
My guess, if a dealer had installed mine, it would have been at least two hours at $140/hr, or $280 + incidentals or over $300. The fabrication issue is where a dealer may get baffled, some are simply not very good at solving problems.
I would certainly go over the entire project, discussing all the necessary changes a service tech was going to make. This reduces the potential for a huge cost, such as one spending huge time in fabrication.
Maybe show them this thread ... the initial post of how I did it.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-25-2017, 05:52 AM   #87
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Scott I had never attempted a switch out like this. But, did on our 2017 Classic, taking out the stock single stage and replacing with a 1260 HW Boondocker I purchased from Randy at his recommendation of Best Converter.
It took me about 2 hours, being careful and having to build a shelf for the converter to sit on and I fabricated a metal piece for the front to which I could attach the brown metal door that was the door on the original converter.
Did this about four months ago and so far all is good. I would think if somewhere around $200.00 or as Msmoto said up to about $300 would be a fair price.
Good luck
Bud
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 01-28-2018, 11:30 AM   #88
2017 27' International
Fall City , Washington
Just wanted to say thanks to MSMoto for a great thread that helped me install my Boondocker 1260. My install took about 2.5 hours mostly because I proceeded slowly to modify the existing chassis to hold the Boondocker, and I stopped al lot to film a video showing the install and chassis modification. Hope this helps the next person:
https://youtu.be/BcShxL1xO7Y
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 01-28-2018, 12:12 PM   #89
2007 22' International CCD
It looks great. Very helpful because Iím planning the same changes to my AS.
The only question I have is that now you have the two fuses in the Boondocker buried in the chassis, kind of out of reach if you happen to blow one. Iíd consider salvaging the fuse holder off the old convertor, extending wires into the new convertor and mounting the old fuse holder into the original hole to make it possible to replace a fuse if it goes out. When I do mine, Iíll try to get video or pictures if I can solve this one.
Other than that minor consideration, itís a super helpful video, and I appreciate you taking the time to make and post it! Thank you very much!
Old 01-28-2018, 01:04 PM   #90
I had the same thought but didnít want to crack open the Boondocker. Would love to see your solution to relocate the fuses.
Old 01-28-2018, 02:03 PM   #91
Iíll have to crack open the boondocker. AS is in storage and itís a bit too cold to pull the chassis out, but the boondocker is still in a box. Iíll dig into it first chance I get.
Iím not worried about busting the warranty...
Old 01-29-2018, 06:11 AM   #92
paiceman's Avatar
I simply put the boondocker in with fuses facing front. In nine months, exceptional
SAFE TRAVELS
Bud
Old 02-09-2018, 02:53 PM   #93
Boogieshoes's Avatar
2016 30' Classic
Little Rock , Arkansas
Have been struggling with whether to replace our stock Parallax 5355 with a Boondocker. 2016 Classic; factory solar w/AGMs. Dumb question: is the 5355 a single stage charger? Really difficult to determine from reading on their site. This thread has been going on now for some time; is there a better/newer Boondocker now; is there another replacement I should consider?
Regarding the excellent video, I wondered why it was important to place the Boondocker inside the old chassis. Seems that it might dissipate heat better if simply mounted in the space left by removing the Parallax chassis. Has anyone done that and if so, how did they secure the new Boondocker?
I actually think I can do this install, but want to be very careful and not screw up my otherwise great AS.
_________________________________
Boogieshoes, DH of JudyJudy; AS "Rose"
WBAC 5932Arkansas Razorbacks Unit
2016 F250 KR 6.7 4x4 CC "Tex"
Members, NTAC
Boogieshoes is offline   Reply With Quote
Old 02-09-2018, 08:20 PM   #94
mojoe7009's Avatar
The 5355 is a single stage. I put mine in the space where the old one came out. I believe most folks do. Click image for larger version
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 02-10-2018, 02:38 PM   #95
Putting the replacement in the old chassis makes sure the old fuse block and door still fit right. Ventilation should not be an issue.
Old 02-11-2018, 04:33 PM   #96
paiceman's Avatar
I put mine in and did not use the metal box that held the parallex. I built a plywood platform and mounted the Boondocker on it with fuses facing out toward the hall. Nine months, about 90 nights, when stored always plugged in, working fine. I carry the stock parrallex with us as a backup.
SAFE TRAVELS
Bud
Old 02-12-2018, 06:54 PM   #97
I used the old chassis because I didnít want to craft a platform and make a bracket to hold the fuse board.
A week later noticed my fan in the Boondocker wouldnít shut off, even when the charging voltage dropped to 13.2v. Called Randy and he immediately shipped a replacement out, thinking I have a defective temp sensor for the fan. Great customer service!
When I reinstall the replacement I might revisit the mounting orientation so I can better access the fuses on the Boondocker.
Old 02-12-2018, 09:16 PM   #98
New Borockton , Alabama
Images: 21
You did a fantastic install and many have called to ask about it. As for access to the reverse polarity fuses, they will never blow unless you cross the polarity and while that is certainly possible, it's unlikely. Those that have done that are not nearly as far along in DC knowledge as you. Just don't do it!
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 02-19-2018, 04:17 PM   #99
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Your video is outstanding. Iím making the same changes and this video serves as my guide. Thanks for sharing.
Cispook is offline   Reply With Quote
Old 02-21-2018, 03:25 PM   #100
2007 23' Safari SE
Annandale , New Jersey
Have done a lot of reading here and have a call in to Randy at Bestconverter.
Will be upgrading as my present batteries as showing some age/use and only 65AH. So want to replace the converter now, before new batteries are installed.
So the burning question is PD or Boondocker ? At this point I am going with Lews suggestion of the PD4655. Is there a reason others have gone with the Boondocker other than price ?
Fred L is offline   Reply With Quote
3 Stage Charger Jfed Electrical - Systems, Generators, Batteries & Solar 21 10-30-2016 09:42 PM
New 3 stage converter install mayco Classic Motorhomes 3 05-03-2014 03:14 PM
Solar addition to system with a multi-stage converter/charger drboyd Electrical - Systems, Generators, Batteries & Solar 1 03-01-2014 06:59 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 11:21 PM
Want To Install 3 Stage Charger 1999 Safari Soyboy Electrical - Systems, Generators, Batteries & Solar 3 04-15-2010 06:27 AM
