Old 01-30-2015, 11:23 PM   #41
1988 29' Excella
Plant City , Florida
Yep Randy at Best converters will fix you up
wjcwill is offline   Reply With Quote
Old 02-08-2015, 10:44 AM   #42
1969 18' Caravel
Fort Worth , Texas
Bought my boondocker converter and fb-9 fuse panel from the wonderful and infamous Randy. Pretty sure we know how to hook up the converter but does anyone have any advice (or a diagram?!) for installing and hooking up the fb-9?
SarahCaravel is offline   Reply With Quote
Old 02-08-2015, 06:30 PM   #43
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Randy should have that info .Did you check his website?
Old 02-08-2015, 07:29 PM   #44
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by rgwatkin View Post
So, I have a 2012 28ft FC with a Paralax 7300 installed. After three years my Lifeline AGM batteries are a little tired and I want to replace them but not until I replace the converter. My current converter is rated for 55amps as installed from the factory. After reading this thread I have a couple of questions. 1) Is there anything technically wrong with the Magnatech/Paralax upgrate? It appears to be an easy install without getting into a large reconfiguration project. 2) who/where do you buy the upgrade kit? 3) I did read here that someone installed a Powermax PM4-60 4 stage but did have to make some modifications. Is the advantage of the 4 stage so great over the three stage?
Your Lifelines are 'tired' of being improperly charged for 3 years. You can thank your Parallax for killing them prematurely by neither providing them a full charge or a proper float charge!!! NO PRESENTLY AVAILABLE CONVERTERS have the exact required charging profile that Lifelines require. Some, like Progressive Dynamics with Charge Wizard come close, but they are not spot-on either!!
Lifelines require a bulk/absorption charge of 14.2-14.4VDC (@77F) and a float charge of 13.2VDC at the same reference temperature. Part of the problem with converters is that their charging voltage profiles are set and NOT ADJUSTABLE for different types of batteries, nor do they vary their charging voltage with the ambient temperature of the batteries (temperature compensation), the duration of the absorption cycle (battery bank size), or the amperage of the float cycle (should be 0.5 amps/100 amp/hours of battery capacity).
Will they work....sure....and far superior to the Parallax unit. Some folks have Lifelines going on 7 years using either Progressive Dynamics or IOTA converters....which is great! There are other, better alternatives, but as with anything that is superior......there is a greater cost involved.
Old 03-02-2015, 10:00 PM   #45
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
Just received my boondocker. Thank you all for the info.
It takes a big man to cry....it takes an even bigger man to laugh at that man.
bullet661 is offline   Reply With Quote
Old 03-04-2015, 12:10 PM   #46
2013 30' International
Kennewick , Washington
Just ordered the powermax pm4b-60 for my 2013 30 foot signature and am interested in what modifications I will need to make if any. Thanks
Garmat is offline   Reply With Quote
Old 03-04-2015, 12:13 PM   #47
What is the difference between the boondocker model and the powermax pm4b-60
Old 03-04-2015, 12:24 PM   #48
Ok they are the same just a manufacturer title.
Old 03-04-2015, 06:16 PM   #49
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Going on right now tonight, wish me luck. Just posted to my instagram feed.
The install is a little different on the 27FB but about the same.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-04-2015, 07:00 PM   #50
Nomadic , USA
Can someone please explain how they wired the 120V? Also what is the bonding common line?
A little frustrated that the directions for this thing are 3 sentences.
It was easy enough to figure out the two wires from the original to the plus and neg but the common one I'm not sure I follow on that.
Name:	2015-03-04 19.57.22.jpg
Old 03-04-2015, 09:15 PM   #51
Nomadic , USA
Never mind I figured it out.
Old 03-04-2015, 09:47 PM   #52
lewster's Avatar
Ahhhhh, the PD-4655 is a direct replacement for the Parallax that you removed. Comes with a very nice new DC fuse block too.....even has little red LEDs on it to show you which fuse you just blew...no more fuse tester!!!
Old 03-05-2015, 12:03 PM   #53
Nomadic , USA
Installed now. Time will tell.
Old 03-09-2015, 07:54 AM   #54
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Looks good to me.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 03-09-2015, 11:56 AM   #55
Nomadic , USA
I'll tell ya what, bending that copper to the chassis ground was a pain, lol. But I'm happy with it, and my Airstream didn't burn down, which is always a plus.
Old 03-09-2015, 08:53 PM   #56
lewster's Avatar
I feel your pain! If you think solid copper wire is tough to bend......try THIS stuff............ I use the solid copper bar for connections where welding cable would be too sloppy. Things like shunt-to-battery, shunt to terminal block, inverter fuse to disconnect switch, etc. Makes for a nice clean installation.
Old 03-09-2015, 10:53 PM   #57
1974 Argosy 20
Kooskia , Idaho
And if you can't get solid copper bar like Lew uses, you can take a piece of half inch copper pipe, put it in a vice to crush it flat, and then drill holes in it for the connections. Bend as needed like the photo Lew shows. Tape the bar. Makes excellent heavy solid connections.
Old 07-14-2015, 07:38 PM   #58
Damien
tot2learn's Avatar
2012 27' FB International
Lafayette , Colorado
Thumbs up
Thanks to this post from Msmoto, I installed a PowerMax PM4B-60 over the weekend.
While I was at it, I replaced my dead group 24 batteries with new Interstate Group 27s.
I haven't decided whether it's necessary to fashion a bracket for the fuse panel, for now I just screwed one side of it to the converter like the old Parallax 555 had.
And yes, I ordered the convert from Randy at BestConverters.com
ID:	242988   Click image for larger version
tot2learn is offline   Reply With Quote
Old 07-14-2015, 09:07 PM   #59
lewster's Avatar
If you had turned your batteries 90, you would have been able to fit them into the existing battery box with no modification.
Old 07-15-2015, 12:26 AM   #60
Damien
tot2learn's Avatar
I saw your post about that with the Lifeline 27s so I tried doing it that way first. It didn't work for me, unfortunately. These batteries were a 1/4" too wide.
3 Stage Charger Jfed Electrical - Systems, Generators, Batteries & Solar 21 10-30-2016 09:42 PM
New 3 stage converter install mayco Classic Motorhomes 3 05-03-2014 03:14 PM
Solar addition to system with a multi-stage converter/charger drboyd Electrical - Systems, Generators, Batteries & Solar 1 03-01-2014 06:59 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 11:21 PM
Want To Install 3 Stage Charger 1999 Safari Soyboy Electrical - Systems, Generators, Batteries & Solar 3 04-15-2010 06:27 AM
