Old 06-12-2016, 04:30 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Installed PD-4655
I installed the PD-4655 converter/charger today. There were two surprises.
The first is that the unit in my was 2009 25FB was not a Parallax but was a WFCO. I was surprised because there was no documents or stickers on the panel cover indicating the original unit had been changed. I never heard of WFCO so I don't know if it is a three stage charger or not. But Since I had everything torn apart I just went ahead and installed the new PD-4655.
And the second surprise, it seems as though everything is working as it should. I had a little difficulty getting the holes to line up and had to do some filing on the case to get the screws to start. It was difficult lying on the floor doing the work but with patience the job is done!
Does the WFCO have any value? Just curious.
Thanks for all the recommendations and input from forum members which gave a complete novice on electrical projects (me of course) the confidence to get this done!
Old 06-12-2016, 06:03 PM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I had the same issues getting the holes to line up when I installed my PD unit. I used a roto zip tool to enlarge them a bit so I could get the screws started.
Mike
Caffeinated is offline   Reply With Quote
Old 06-12-2016, 06:19 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My biggest surprise was how easy the swap went. Watched a couple of YouTube videos and jumped right in.
MICHAEL
Old 06-12-2016, 08:06 PM   #4
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I believe the WFCO is made in China. The also manufactured the transfer switch in my 28' 2012 Intl CCD. I think just about everyone with the WFCO transfer switch had to have them replaced.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-12-2016, 08:11 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
WFCO= World Friendship COmpany. They have been around for a while but still Chinese cheap components that don't last. They were a 3-stage unit though.
You are much better with the PD.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installations
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 06-13-2016, 03:36 AM   #6
Long Island , New York
You guys might want to follow the thread reporting possible noise problems with a batch of the 4655's:
http://www.airforums.com/forums/f37/...se-151312.html
Lew have you heard anything about this issue? We are considering the same PD4655 upgrade.
Peter
OTRA15 is online now   Reply With Quote
Old 06-13-2016, 05:19 AM   #7
AWCHIEF's Avatar
Images: 33
I believe that issue was fixed some time ago. I have had no problems with my PD.
MICHAEL
Old 06-13-2016, 05:41 AM   #8
Thanks Michael.
Peter
Old 06-15-2016, 04:39 PM   #9
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Well There are so many to choose from why this one? Want to change mine but don't know what one to get. Looking for some ideas. Want a 4 stage that I know and we like to boondock when we are not working. Thanks
beetlebob is offline   Reply With Quote
Old 06-15-2016, 05:19 PM   #10
Hans627's Avatar
The reason I chose this one was, 1) because it was highly recommended by members of the forum whose opinion I have come to trust and, 2) it is a retrofit for the Parallax unit and fits into the same opening without having to modify the cabinet in which it is housed!
Perhaps that is somewhat helpful!
Old 06-15-2016, 10:36 PM   #11
lewster's Avatar
And don't forget that all Progressive Dynamics components are designed, manufactured and serviced in Michigan (that's in the USA!) and all of their components are of high quality from a company that stands behind them.
What other reasons do you really need??
Old 06-16-2016, 06:00 AM   #12
AWCHIEF's Avatar
Images: 33
I choose for the same reasons as listed by Hans and Lew. Very important was direct drop in replacement. After watching the available YouTube videos a dozen times it was almost plug and play.
MICHAEL
Old 07-06-2016, 03:22 PM   #13
2016 28' Flying Cloud
The Plains , Ohio
So is it (PD 4655) a direct replacement for my Parallax 5355 in my 2016 FC28?
Richard
whitegs is offline   Reply With Quote
Old 07-07-2016, 09:02 AM   #14
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
Richard
There is a Progressive Dynamics model that replaces a WFCO and at least one model Parallax.
You should contact Randy at sales@bestconverter.com. He would definitely know for sure.
NWGetaways is offline   Reply With Quote
Replaced a Paralax 7355 with PD 4655 converter Rrroberts40 Electrical - Systems, Generators, Batteries & Solar 83 12-24-2017 02:26 PM
Progressive Dynamics 4655 (PD4655) noise waldosgone Electrical - Systems, Generators, Batteries & Solar 47 10-31-2017 11:56 AM
PD 4655 install video. AWCHIEF Batteries, Univolts, Converters & Inverters 40 08-08-2015 12:34 AM
PD 4655 Question? rgwatkin Batteries, Univolts, Converters & Inverters 7 07-08-2015 01:51 PM
PD 4655 - How long to Float Voltage? Alphonse Batteries, Univolts, Converters & Inverters 6 10-08-2014 11:58 PM
