Old 07-07-2016, 09:11 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by whitegs View Post
So is it (PD 4655) a direct replacement for my Parallax 5355 in my 2016 FC28?
Richard
PD has a direct replacement chart on their web site.
MICHAEL
Old 07-07-2016, 09:22 AM   #16
JimGolden's Avatar
1977 31' Excella 500
I also did a Progressive Dynamics install. But, I changed out the entire panel. Had to modify the cabinetry, but it made a very nice job. Have been very pleased with it. My coach was originally 30amp; now it's 50amp. The PD unit is nearly silent. My older unit made lots of noise. My batteries stay nicely topped off but without cooking, as the old one did. Overall, very happy with them.
- Jim
JimGolden is offline   Reply With Quote
Old 07-07-2016, 10:03 AM   #17
2016 28' Flying Cloud
The Plains , Ohio
Originally Posted by NWGetaways View Post
There is a Progressive Dynamics model that replaces a WFCO and at least one model Parallax.
You should contact Randy at sales@bestconverter.com. He would definitely know for sure.
Randy thinks a Boondocker converter is what I need. The installation looks complicated. At my age (80) I've lost a lot of my ambition
whitegs is offline   Reply With Quote
Old 07-08-2016, 04:44 AM   #18
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Richard
Yes!
I agree with comment about it being quiet!
Old 07-21-2016, 12:41 PM   #19
stephenb's Avatar
2011 25' FB Flying Cloud
Hutchinson , Kansas
Is the progressive dynamics unit ok to use with agm's or is something better?
stephenb is offline   Reply With Quote
Old 07-21-2016, 01:48 PM   #20
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I've installed the PD in two trailers -- 2012 28' Intl CCD and 2015 30' Classic. Both with AGM's. It's a great upgrade from the crummy WFCO....and really important to move away from that piece of junk when you're using AGM's. The last thing you want to do is overcharge them....and the PD will keep them perfectly charged all the way up to when it floats them. Actually, I don't think I would even consider spending the $ on AGM's without a better charger/converter unit than the WFCO.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-21-2016, 04:33 PM   #21
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
Not a direct replacement for a Series 500 model 555
I have a Parallax series 500 unit. Picked up a PD-4655 thinking it would be a drop in replacement but I found out the hard way it was not. Apparently there is a Parallax drop in replacement that has a deeper tray than the Model 555 which turns it into a 5355.
Decided to do some field mods and I was able to get the control board mounted and the two fans. Mounted the fuse board to the front of the tray where the original was. In the end it looks great and seems to work awesome.
rdepas is offline   Reply With Quote
Replaced a Paralax 7355 with PD 4655 converter Rrroberts40 Electrical - Systems, Generators, Batteries & Solar 83 12-24-2017 02:26 PM
Progressive Dynamics 4655 (PD4655) noise waldosgone Electrical - Systems, Generators, Batteries & Solar 47 10-31-2017 11:56 AM
PD 4655 install video. AWCHIEF Batteries, Univolts, Converters & Inverters 40 08-08-2015 12:34 AM
PD 4655 Question? rgwatkin Batteries, Univolts, Converters & Inverters 7 07-08-2015 01:51 PM
PD 4655 - How long to Float Voltage? Alphonse Batteries, Univolts, Converters & Inverters 6 10-08-2014 11:58 PM
