Hi - I have a 2010 28' International. I recently moved into a new house and had the electrician install a 30amp trailer outlet outside my house. Unbeknownst to me, the electrician doesn't read and hooked the 30amp plug to a 220V circuit instead of 110V.
I discovered this when I plugged in my trailer for the first time and saw smoke/sparks come from the Paralax 7300 panel.
The electrician (who came over quickly and sheepishly admitted never having read the directions or the box that came with the outlet) fixed the circuit, saw that my 110V GFI breaker was fried and replaced it. After that, we powered everything up and all seemed to work and be fine.
No problems for a few days (we are living in the trailer now while our house is still under construction) until I noticed my battery level is very low. (both the solar control panel and the monitor show it less than 50%.
Upon further inspection, I discovered the converter was fried. One of the large resistors (I think that's what they are) was busted open. I installed a new 7300R replacement converter/charger (the lower section) and all seems ok but, even after having the new converter running for several housrs, my batteries are still going down and I don't think the converter is working properly.
I'm trying to troubleshoot and need a little help. Even after replacing the converter/charger, something is wrong - I don't think the
12V panel is getting power from the converter thus, even though I'm hooked to shorepower, I think the house batteries are still supplying
12V power inside and not getting a charge so running down.
I checked all the 100V breakers and
12V fuses in the power panel and all are good. Are their other breakers/fuses I need to check? Way under the front couch is the wiring where the 12V comes into the trailer though I'm not familiar with this part of the electrical system and don't know what breakers/fuses may be present. There are 2 on the top of the battery disconnect that I checked and they are fine.
My 100V system works fine - no problem with AC, 100V plugs, etc.
With my 110V running, if I put the battery disconnect to "store", I loose all 12V power in the trailer - if I have the 110V connected, shouldn't the converter provide 12V power so internal lights, etc. stay working even if the switch is in "store" mode? USE mode is OK/STORE mode kills all the 12V even if 110 is connected.
Solar seems OK. I'm getting a good amount of charge from the solar during the day but not enough to bring them back to 100% and, as soon as it's gets dark, even though I have the 110V plugged in and a new converter/charger, my batteries are still running down.
Any suggestions on how to test to see if the converter is working properly?
How to isolate the batteries from the system to see if the converter can provide 12V power to the coach? Also any suggestions on other places where fuses/breakers may have been damaged would be welcome.
Fortunately the weather has been good the last several days so my batteries are getting charge from the solar panels though the family (3 of us) is living in the trailer so there are still 12V demands all day and, once the sun goes down, the charge slowly goes down.
All suggestions welcome!
