02-17-2018, 06:08 AM
1972 23' Safari
Middletown
, Rhode Island
inline fuse, how far from battery...
How far from the battery can I hook up a inline fuse for my 2000w inverter? I originally tried to put a inline fuse in my battery box with my battery but the fit was too tight, can I install it further away outside my battery box closer to my inverter which is located about 5 ft away inside my closet? What's the furthest distance can I go? Thanks.
02-17-2018, 07:08 AM
Milford
, Ohio
Any distance should work, but the closer you are to the battery the safer you will be.
By safe, I mean that regardless of if the fuse is blown or even in place, the wire from the battery to the fuse holder will always be live. If cut accidentally, no fuse to blow and protect you, since that fuse is 'upstream'.
Hope that makes sense.
Christopher
Its a camper, therefore it leaks.
02-17-2018, 07:13 AM
1972 23' Safari
Middletown
, Rhode Island
Got it, makes sense. Thanks. I plan on installing it about 2-3 ft away from my battery.
02-17-2018, 07:46 AM
Overland Adventurer
2009 34' Panamerica
Telluride
A fuse is there to protect the wire. Should be within 8" of battery.
02-17-2018, 08:01 AM
1972 23' Safari
Middletown
, Rhode Island
no choice
I would but can't because it won't fit in my battery box, so I have no choice but to install it 2-3ft away which puts the inline fuse right in my closet next to where my positive line exits the trailer and goes into the battery box. I guess having a fuse a little further away is better than not having one at all. I'm also running 4awg wire from my inverter to my 200amp inline fuse and then to the battery.
02-17-2018, 08:03 AM
1972 23' Safari
Middletown
, Rhode Island
one more question...
How many lines can I put on my positive terminal on my battery? I need to put 3 on, 1 from my victron battery monitor, inverter, and main positive line to my converter/charger.
02-17-2018, 09:45 AM
2007 25' Safari FB SE
North/East
, New Jersey
Mx468.......I'm not aware of a RV standard regarding the number of terminals you can connect to a battery stud. In the boating industry there is an American Boat & Yacht Council (ABYC) standard E-11 that restricts the number of terminals connected to a battery stud to 4 terminals.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
02-17-2018, 09:51 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
Right Answer
Sir you are correct.
Signed
An Old Retired Engineer
02-17-2018, 09:53 AM
The Panhandle
, Idaho
Had this same issue on our last trailer (a Starcraft) when adding a line for the power tongue jack. No room for the fuse holder inside the battery box. I found a fuse holder at West Marine that was rated for wet locations and marine use. In 10 years after installation I never had one issue with it.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
02-17-2018, 10:00 AM
Curtis Wright
Eyren Haven
, South Jersey
I ran the fused battery positive to a Blue Sea buss bar. Then cables from bus bar, each with a fuse. I used these terminal mounted fuses. https://shop.marinehowto.com/product...d-battery-fuse
02-17-2018, 11:07 AM
1972 23' Safari
Middletown
, Rhode Island
If I put 3 lines on 1 positive side battery terminal can I just stack them on top of each other? I tried to fit a extra terminal on my battery post but it’s a tight fit.
02-17-2018, 03:30 PM
2004 30' Classic
Johnson City
From ANSI/RVIA LV "Standard for Low Voltage Systems In Conversion and Recreational Vehicles": "The overcurrent-protective device shall be installed in an accessible location on the vehicle within 18 in. (457 mm) of the point where the power source connects to the vehicle circuits."
Recommend placing it as close to the battery as you can, but no more 18" from the battery.
Also from ANSI/RVIA LV:
"6-1.14 Stacking. No more than four terminals shall be secured to any one terminal stud. If additional connections are necessary, two or more terminal studs may be connected together by means of appropriately sized jumpers or copper straps."
Am confused on the 4 AWG and 200A fuse. From ANSI/RVIA LV, for a 105 C rated 4 AWG, the maximum ampacity is 120 A. From ABYC E-11, Table VI-A, the maximum ampacity for a single, unbundled 4 AWG, 105 C conductor is 160A.
Your inline fuse protects the wire, and, taking the most restrictive, should be no more that 120A. For 200A, you should be using 2 AWG 105 C conductor or larger. You might need larger depending on the total length and voltage drop.
73/gus
Dr. Gus Lott, P.E.
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
02-17-2018, 04:05 PM
2017 27' International
Lake Havasu City
Just a thought: could you use a Marine-Rated Battery Fuse (MRBF)? These are heavy-duty fuses that mount directly on top of a battery post, and provide a terminal post that you can attach your cables to.
Two gotchas: an MRBF adds a couple of inches of height, so you need adequate vertical clearance in your battery box. And they're made for threaded battery posts, not lead posts, so if you have standard automotive batteries, you'll need post adapters. Still, if they'll fit, they are an excellent solution that puts the fuse right on the battery--no worrying about an unfused length of cable between battery and fuse.
02-17-2018, 11:07 PM
1972 23' Safari
Middletown
, Rhode Island
73/gus
Dr. Gus Lott, P.E.
I actually meant 2awg wire, not 4.
