06-13-2012, 02:49 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
If my batteries are done.....
Shouldn't I be able to use my electric jack while plugged into shore power?
Thanks.
Shane
06-13-2012, 03:01 PM
2016 25' Flying Cloud
Sunnyvale
If batteries really dead, you'll need to use the crank.. The power supply puts electricity into the battery or batteries, but the 12V subsystem runs off the stored electrical charge in the batteries..
Condoluminum
06-13-2012, 03:03 PM
A.K.A "THE STREAM"
Arlington
Thanks...anything else I can't use while on shore power?
Shane
06-13-2012, 03:05 PM
1974 Argosy 20
Kooskia
, Idaho
Yes, you should, if it is wired properly and all is still connected. But I note you have a 2010 unit and I know they have some kind of a Use/Store switch which I am not familiar with and it may be wired differently than the AS's and Argosy's that I am used to... up to about 1990 or so.
06-13-2012, 04:02 PM
Sioux Falls
, South Dakota
Before I removed the electric jack it worked on shore power if the converter was plugged in. It worked with battery removed.
06-13-2012, 05:07 PM
Oswego
If you disconnect the batteries the converter will power your 12V items. Tape up the positive cable ends though. I wouldn't run the converter long with no batts. They act as a voltage "sink" or "buffer" to the fluctuations the converter might experience with varying loads. But if you just need to get hitched and do a couple of other "emergency" things, I'd do it that way.
-Rich-
06-13-2012, 08:17 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Our electric jack will sometimes blow the 30 amp fuse ... not sure if your converter puts out that much direct amperage. I would suggest that you allow the batts to recharge a bit before using the camper jack. Also avoid straining the jack motor at either the fully up or down position ... that really increases the current load.
06-13-2012, 08:46 PM
Retired.
, At Large
Your jack will not work using the converter only when the batteries are disconnected. The small black wire that goes to one of the batteries supplies power to the jack and breakaway switch. The converter feeds power to the battery terminal, and that is where the connection is.
06-13-2012, 09:29 PM
Sioux Falls
, South Dakota
This is how mine is wired:
http://www.airforums.com/forums/atta...1&d=1298763182
The blue wire at the top right of the fuse block is a #10 wire that connects to the 7-way fuse block and powers the breakaway switch and powered the electric jack before I removed it. The jack lifted fine on shore power with no battery installed.
06-13-2012, 09:32 PM
Ottawa
, ON
Our jack will work with no battery if the umbilical is connected to the TV.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
06-14-2012, 03:37 AM
Retired.
, At Large
Aage, the way our older trailers are wired is different from Shane's. He has two batteries mounted in the tool box on the A frame, snd ours have single batteries mounted in a compartment at the rear of the trailer.
His teailer is wired with a pair of automotive cable end coming from inside to one battery, with a pair of jumper wires going to the second battery. The breakaway switch and jack are on a separate wire that will need to be attached to the threaded terminal where the positive jumper wire is connected.
06-14-2012, 11:01 AM
Small Town
Did I miss something ... has Thepill removed or disconnected the batts?
06-14-2012, 11:12 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
There isn't enough info to answer the question. Are batteries installed? Are they dead? Is the jack fuse blown? Is the wire to the jack ok? Did it work before being plugged into shore power? Are the gears in the jack greased and not stripped?
Gene
06-14-2012, 12:40 PM
A.K.A "THE STREAM"
Arlington
I must have won the lotto....one battery was dry..I filled it up and waited about 3hrs...works great now.
Thank you all!!
I can see new batteries inthe future,though.
Shane
06-14-2012, 01:07 PM
Master of Universe
Grand Junction
Good. You avoided, for now, the battery grim reaper.
Now check them frequently to see if they hold a charge.
Gene
06-14-2012, 02:17 PM
Ottawa
, ON
Thanks for the explanation, Terry.
06-14-2012, 06:21 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Thanks.
Shane
Yes....ours duz. Even without the batts installed.
