Old 12-15-2008, 06:50 AM   #15
Originally Posted by ROBERTSUNRUS View Post
Hi, The best way to recharge any totally dead battery, [FLA] flooded lead acid, is to slow charge it. You need to charge dead battries at 2 amps or less for 24 to 48 hours. Fast or high amp recharges, cook batteries and or burn out battery chargers.
And make super sure that the polarity is followed.
A dead battery can easily be reverse charged.
A showed many students what the result of that can be, especially when you installed a reversed charged battery in a circuit with correctly polarized batteries.
BANG, SMOKE AND FIRE, INSTANTLY.
Old 12-15-2008, 07:03 AM   #16
1984 31' Excella
Norfolk , Virginia
Images: 11
Dead Battery
altimont
The best way to charge completely dead batteries is with a trickle charger (2 amps or less until fully charged (no longer drawing current) of 48 hrs atleast. Always be sure you have the polarity correct (red to +, black to -) cach cell full to fill ring (app. 1/2 to 1 inch depending upon maufacturer) and in a vented area (not around a gas appliance (gas water heater) with an open flame.
If you battery charger has an apm meter you might notice that when you hook up the battery charger to the battery, the battery might not draw any current (zero amps), often a dead battery will start out this way. Leave it for several hours and check back on it. The current will eventually come up.
Beginner
Beginner is offline   Reply With Quote
Old 12-15-2008, 07:12 AM   #17
Originally Posted by Beginner View Post
altimont
Beginner
And if it doesn't come back up, have a beer and buy a new battery.
The rule is "never, never, ever", allow a lead acid battery to completely discharge.
Old 12-18-2008, 10:11 AM   #18
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Well, I got back to town and the battery charge meter reads 100%. Maybe I won't have to replace the batteries right now after all. I was sort of hoping they were toast as I want a couple of AGM's. Very expensive though and Christmas for 6 kids, 6 spouses and 12 grandkids is getting pretty expensive.
altamont is offline   Reply With Quote
Old 12-18-2008, 12:11 PM   #19
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Glad it worked out.. it usually does.
have a Merry Christmas..
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 12-18-2008, 12:34 PM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
"6 spouses"?? All at once?
I suspect mine are ok too and having the same "toast" desire. I've wanted to check the specific gravity in the cells, but since last Saturday we've had one snow storm after another (16" so far) and today it's blowing hard and snowing off and on and supposed to stay this way through Christmas. I can't face checking the batteries in this weather. One week it's in the 40's every day, dry as dust and sunny, and the next, mid-winter. You'd think I lived in Colorado.
The voltage on the solar panel has dropped from 12.8 to 12.6 with shore power unplugged and the panels covered with snow. That amounts to 100% I think. Some energy gets to the panels through the snow (.1 or .2 v when I've checked) and pretty much is a trickle charge.
Gene
Old 12-18-2008, 12:37 PM   #21
moderator
Airslide's Avatar
Wilton , California
Images: 50
Wow Gene... and im complaining about 30* temps here in Calif..
16" inches of snow? Stay warm!! The airstream will be fine.. she's just chillin right now dreaming of the spring campout!
Old 12-18-2008, 10:45 PM   #22
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
Regarding multi-stage chargers in this thread. My understanding is that none of the Magnetek/Parallax converters have three stage charging. I talked with an engineer there two years ago and he told me they don't think it is necessary and has certain problems when you are trying to maintain voltage in the 13.2 to 14.2 range to properly supply 12 volt appliances.
Parallax does have a two stage option on some models with a T in the model number but that model is not used by Airstream. Regarding the 7400 model, one can review the brochure for that model at: http://www.parallaxpower.com/7400/74...ctbrochure.pdf
and other models can be looked up at: Electronic Switch-Mode Power Converters
Best Converter does have replacement charger sections to provide 3 stage charging but I believe they are from an aftermarket company rather than the original manufacturer.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 12-19-2008, 01:40 PM   #23
Master of Universe
Gene's Avatar
Now that I've looked at the paperwork, it's true the Parallax does not have a 3 stage charger. The ones with the "T" option use a timer. The converter charges at 14 v. for 13 hours after it's plugged into shore power, then goes down to 13.5 v. to prevent overcharging. If you unplug it for 2 minutes, then it goes to 14 v. again for 13 hours and the cycle repeats. Kind of crude system. The paperwork is for a series 7300.
Later I'll go look at the converter to confirm model number and the absence of the "T" option.
The Airstream owner's manual says different things. First, it calls it a MagneTec converter. Both companies have Indiana addresses, but I don't know if they are one and the same. There really is no clear guidance about overcharging. It does say "The charging circuit automatically controls the current, reducing it as the batteries increases in charge." Ignoring the grammatical mistake, the Parallax paperwork says the same thing. Current = amps, not volts. It seems to me amps will reduce to nearly 0 when a battery is fully charged because there's no load (except for propane detector and some other items that draw small amounts of amps from time to time) and this has nothing to do with overcharging.
When storing the trailer, the owner's manual advises to take out the batteries, put them in a cool and dry place so they won't freeze, and charge them periodically. I'm not sure who has a cool, well ventilated place where we have real winter. It isn't good to store batteries inside because of the potential for nasty gas to build up, so I leave them in the trailer.
The solar panel appears to have a three stage charger and should keep the batteries ok. So I'll keep the shore power unplugged except when I need to run the heat or refrigerator and will monitor the batteries. If the charge gets low, I can plug in shore power for several hours.
Gene
Old 01-11-2009, 10:32 AM   #24
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Vintage Battery Question
When boondocking, I had the fridge running on 12v until I noticed that it wasn't. Battery out of juice. Is there a gadget that I can add to measure battery status and cut it off before deep discharge, saving the battery from damage?
bevman is offline   Reply With Quote
Old 01-11-2009, 10:46 AM   #25
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Running the fridge on battery will not last long, propane is the preferred method without hookups. I would check with Randy at BestConverter - Converters, Inverters, Electrical Supplies, Electronics to see if they have the device you are looking for. They do have a monitor that alarms when a thresh hold voltage is reached: Voltminder
Richard
Old 01-11-2009, 12:04 PM   #26
bevman's Avatar
Thanks for that lead. I'll check with Randy. (The PO changed out the three way fridge in 1974 to a 120/12v Norcold -- I'd love to find a vintage unit to put back, one that had the propane option).
Cheers!
Old 01-11-2009, 12:24 PM   #27
Master of Universe
Gene's Avatar
Bevman, I understand the desire to restore everything to original, but the new refrigerators are so much better—more efficient, don't need to be almost perfectly level and better in all other ways. Having remodeled a 1919 cabin in the 1990's, I had to struggle all the time to balance between modern conveniences (such as insulation that worked; we did find a 1930 stove that worked perfectly and we brought it with us when we moved, but used a new refrigerator) and restoring a much abused building to look like it was supposed to.
Gene
batteries jhenry Member Introductions 5 10-19-2008 02:03 PM
Display modes messed up. thecatsandi Forum Admin, News and Member Account Info 3 12-10-2006 09:47 AM
I think I just messed up my photos--help! dmreilly10000 Forum Admin, News and Member Account Info 6 10-20-2006 12:37 PM
batteries dsmith Electrical - Systems, Generators, Batteries & Solar 7 03-15-2006 07:36 AM
Batteries 85/345 Mechanics Corner - Engines, Transmission & More... 30 01-28-2005 04:47 PM
