Old 05-07-2004, 02:17 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I need battery basics
Ok, I've been reading the battery info on the forum all morning, and my head is spinning. I need just the basic info. I'm not very electrically inclined, thinking about this stuff makes my head hurt!
I have one type 27 deep cycle battery in the Caravel, purchased May '98. It gets charged with the original Univolt. I checked it with an analog multimeter, and it says it has 12v on it now. I plugged it in and the guage swung up to about 13v (I'm wishing I'd bought a digital one now). The label on the Univolt says it charges at 13.5v.
So I'm wondering what do I need to do to maintain the battery - anything? How will I know when it's going bad and needs to be replaced? The only 12v items in my trailer are the lights, everything else runs on propane, so battery usage is pretty light, and while at home I keep it plugged in most of the time so it will be ready to go. I was surprised when we had to plug in on our last trip because the battery was now sufficient to keep the lights on bright.
How many years can I expect to get out of a battery, and is there something I should be doing to help it last longer?
Stephanie
Old 05-07-2004, 02:22 PM   #2
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Type 27
Stephanie,
Is the Type 27 the size of battery made for the Caravel. I pick my Caravel up in a few weeks, and it needs a battery. Looks like a small place to get a big one in, like in my '85 Limited (it takes two) and I want to know the size required? Thanks.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-07-2004, 02:31 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Stephanie,
Voltage is only one of the possible ways to test a battery.
If you have been maintaining the water level properly the battery could just be wore out. 7 years on a battery is actually really good. depending on use, and maintenance 3-5 is the normal life span.
There are 2 other test that you can run or have run. One is a load test. I will bet that it will fail this one. The local auto parts store will have a tester for that. Most do it for free. They want you to buy a new battery.
The other is to check the specific gravity of the electrolyte in the cells. This requires one of those testers that looks like a turkey baster with little colored floats in it. You draw out some of the water/acid mix from each cell and the floats tell you the gravity. These normally run 5-10 bucks. There is also one with a needle/float. This is the most accurate way to check the health of a battery.
Let us know what you find!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 05-07-2004, 04:04 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
RobandZoe, I don't know if the group 27 is original to the trailer or not. The area it is in is large (it's the street-side compartment under the gaucho), and there is pleanty of room to pull it in and out - it's a little awkward and hard on the back, but what else is new?
Thanks Brett, I'll go swing it by the local autoparts store and see what they find. I have a feeling it might not be holding it's charge.
Stephanie
Old 05-09-2004, 07:48 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Well, I tested it a little more at home before going to the autoparts store. My hubby was skeptical that they would tell us anything but 'it's bad', since they're only helping so they can sell you a new one. So I charged it up, and the Univolt shut off when the battery was at approx 13.5v. I turned on the three main interior lights and went about my business. When I came back an hour later the battery was at 9v. That seemed like a pretty severe drop for only having a few lights on.
So I took it to the auto parts store and the first test they did said it was ok, and to proceed to 'recharge and test'. I felt this would be the equivalent of what I'd already done at home. So I went ahead and bought a new battery. The guy was amazed that my 1998 battery was still working for us anyway, so it was probably time.
Stephanie
Old 05-10-2004, 01:51 AM   #6
JanP's Avatar
Wink Battery info
Stephanie, At an International Rally, the "full timer" meeting moderator said that he had given up on batteries and bought a new set every 2 years. Never had a problem after that. I think that Sears deep cycle batteries have a 3 year warrantee now. I use Sears because they are in most every town. They run a full battery of tests and say good or bad. no hassles. Some Univolts do not turn off and boil batteries dry. When at home, I use the best battery charger available- one that automatically tapers off when full charge is reached. No overcharging that way.
Ernie and Jan
JanP is offline   Reply With Quote
Old 05-10-2004, 07:34 AM   #7
LOST , Hawaii
Ernie and Jan
That's one way to keep the meeting short.
John
74Argosy24MH is offline   Reply With Quote
Old 05-10-2004, 08:07 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It seems for me a big helpo on battery life has been disconnecting the batteries when not in use with a blade switch. Cheap and effective. Then if you do see a slight drop in voltage, charge them back up, or use a battery minder to do so.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-10-2004, 09:35 AM   #9
jaco's Avatar
Managing Twelve Volts by Harold Barre
I have yet to read this book.
but it comes highly reccomended in and on many RV sites.
My Library doesnt have it. Think I'll call and arrange an inter-library loan search.
Don't know if it is Current enough to address today's batteries or how much it addresses battery life expectancy at all. Nor do I know if today's batteries are much or any improved over those 20 years ago?
Perhaps someone could advise. Preferably someone who has actually read the book.
jaco is offline   Reply With Quote
Old 05-10-2004, 10:08 AM   #10
Jaco, yes, I've read, learnt, and inwardly digested this book, and it sits on the bookshelf in my trailer. It's a useful reference book, rather than a one time read, as there are various charts of data that are useful. e.g wire sizes, % charge at various voltages. Recommended. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 01:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 06:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
