Old 04-21-2016, 08:40 AM   #1
1975 Argosy 26
Horseshoe , North Carolina
I have no idea how to wire this converter!
We recently bought this 1975 26' Argosy. The original univolt was very loud and caused the lights to strobe. We bought a new powermax 45 amp converter and separate fuse panel. I will attach pics of what we had and what we bought. There was no battery in our camper and no cables/wires going to the battery box. I get the 12v wires go into the fuse panel but I'm not sure what goes into the back of the converter box in the + and - outlets or how you get power from the converter over to the fuse panel. Sorry, I am a bit more challenged than most people when it comes to this stuff. Do any of you have pictures of how yours is wired. I've called several local rv repair people and they won't call me back. Thanks!
ID:	261115   Click image for larger version
Marcello3 is offline   Reply With Quote
Old 04-21-2016, 08:15 PM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
did it come with any type of installation manual. with no battery I would guess it wires into the 120v and then the load side would be your 12v fuse panel.
on my 2005 it, convertor, plug into wall plate and has wires from convertor to hot and ground of battery and to 12v fuse panel.
just guessing here.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-21-2016, 08:38 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I found some excellent video on YouTube when I did my install. Really helped make it a painless project.
MICHAEL
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
The ONLY floor rot I have found. Anyone have a quick fix idea? WILDRTEXAS Repairing/Replacing Floor &/or Frame 8 03-18-2010 06:30 AM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
