Old 08-23-2011, 12:27 PM   #1
1982 31' Excella
Celina , Texas
Humming / buzzing when hooked up to elect
Hi Everyone,
I just purchased a 1982 Excella-31, I have been going through everything and verifying what works and what needs some help. One thing I noticed is when I plug the trailer into electricity it immediately starts a humming or bizzing noise coming from behind or close to the fuse box thatís located in the front of the trailer between the 2 outside battery compartments. I have pulled every fuse trying to diagnose the problem with no success. I only have one battery hooked up but I would not think that would be a problem. The battery is charged so itís not some internal charger. The noise does not seem to be causing any other issues except if you were going to sleep in the couch bed it would be very annoying while trying to fall asleep. Has anyone seen this problem? Any information on how to stop the humming would be greatly appreciated. Thanks
likable_1 is offline   Reply With Quote
Old 08-23-2011, 12:35 PM   #2
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
My guess: converter/inverter?
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 08-23-2011, 12:40 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The converter you have is old technology and the buzz is typical. Replace it with a modern unit (search the forums) that is more efficient, lighter AND quiet.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-23-2011, 12:42 PM   #4
tinman1's Avatar
2002 30' Classic
East Central , Alabama
We had a similar experience with a 1993 25' Excella, found that the humming noise was from the converter. The '93 had a switch under the curtain on sidewall that could be switched "off" when someone was trying to sleep on sofa bed.
Curt, Joan and "BonJovi"
tinman1 is offline   Reply With Quote
Buzzing in speaker bradk Audio, Video & TV 5 08-05-2011 09:36 PM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 04:56 AM
HUM from radio when hooked to shore power The Driver Audio, Video & TV 5 07-12-2011 06:42 AM
Can we run ac w/out dc battery hooked up?? lynxranch Electrical - Systems, Generators, Batteries & Solar 6 07-11-2011 10:11 PM
Factory hooked up gas detector wrong! lsrart1 General Repair Forum 6 01-13-2011 02:51 PM
