Old 06-21-2007, 09:17 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
How's my Battery?
don't do much boondocking, but I'm about to partake in a weekend of self-contained fun....
not sure I really trust the battery (conventional lead acid group 27 deep cycle). Its only a couple of years old, but has given indications of not holding a charge that well. Seems to run down too quickly...of course, that could just be my own mis-calculation of my consumption, but anyway...
hasn't needed water in a long time...and I do check it. I don't leave it plugged into my original univolt for long periods of time.
The trailer has been idle for 3 weeks, running the fridge (which does use some 12v) on gas. stereo was plugged in, too, which also has a phantom load. anyway, voltage was down to 12.3, so I plugged it in and let it charge for 24 hrs. Checked voltage at the battery thismorning (still plugged in to shore power): 13.83v. (seems that the univolt is working properly). Unplugged, and let it rest all day. checked voltage again: 12.7v. sounds good...
then I turned on a light in the trailer...voltage dropped to 12.5. turned on another light: 12.2. is that a normal voltage drop? I know, its not a proper "load test, but I've noted before, it doesn't seem to take much for it to go below 12...
just wondering if I should pick up a new battery before the weekend.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-21-2007, 09:30 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Hey Chuck,
I'm not an electrical guru, but maybe it would be worth the piece of mind to just replace the thing.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-21-2007, 10:54 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
If it has a full charge, that seems to be dropping too fast. I would give it a charge with a battery charger then try it. Or do as Rodney suggests and replace it. If it turns out to be good, you'll have a spare which may not be a bad idea anyway.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-21-2007, 11:41 PM   #4
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
I thought I would add to the confusion on the battery drop. Seeing a 0.2 volt drop or even larger without knowing the demand (watts) of the bulb isn't a very definitive test. I just checked our 25' CCD with six month old Group 24 Gel batteries. The batteries are fully charged to float condition every day by the 260 watt roof top solar panels. The battery at rest voltage an hour before sundown with the refrigerator on was 12.7 (no sun on the panels). An hour after dark the battery voltage is 12.6v. Turning on two 10-watt halogen lights under the front overhead storage didn't drop the voltage for the first 20 secs or so. Then turning on the main ceiling lights, eight 10-watt halogens immediately dropped the voltage to 12.5. My tests didn't run more than a minute but I have seen a 0.2 or more drop when other items are on.
Most likely your battery needs replacing but a definitive answer would be to try and find someon to load test it and see how much it drops for a specified load and campare it to the specs for the battery with you can often find online from the manufacturer.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 06-22-2007, 07:48 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, I know, a legit "load test" would tell you the answer, but its kind of a pita to do.
the lights I had on were the stock 70's light fixtures, w/ the 12v incandescant automotive bulbs. (1156 and/or 1141...can't remember exactly). first light has 2 or 3 of those bulbs; the second has 6...which is quite a hog, I know. I'm not sure of the exact wattage, but that 6 bulb overhead is a significant draw.
it seems that by all indications (so far...), everything is working normally.
no biggie. we're camping w/ the wally club...there'll be generators around, and its not like we're going to the end of the earth or anything. If I run low too quickly, I can just go out and buy a replacement.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-22-2007, 07:56 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Chuck-We loaded out little 1000 gen into the truck for ya! It has 3/4 tank of gas so we got you covered! See you later today.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 06-22-2007, 10:21 AM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Accurate battery test!
Pull the battery out to access both + and - terminals. Now place your tongue across both terminal posts at the same time. If you feel a slight tingle then your battery is low. If you get a moderate zing the battery is good. If you get knocked on you @** then you have a full charge and your battery is, as we say.... Good to Go! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 08:41 AM
Second Battery w9det 1999 Safari 5 12-06-2002 07:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 02:03 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
