Old 09-23-2012, 06:57 PM   #1
JackP's Avatar
1972 27' Overlander
New Haven , Connecticut
How/where do I bond my new converter?
I just replaced a univolt with a new converter and 12V distribution panel in my '72 overlander. Everything went well except that the univolt I removed was not bonded to the trailer and I have no idea where to bond the new converter to.
I purchased 5' of 8 AWG wire, color green, and have it attached to the converter. I'm just waiting to figure out what to bond it to.
My converter is located under the tub on the curb side in the rear of the trailer. I access the converter through a door in the side of the trailer or by removing the bed.
Thanks in advance for your help.
Jack
JackP is offline   Reply With Quote
Old 09-23-2012, 07:03 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Are you trying to ground it? If so, simply attach the wire to the lug provided on the converter, and bolt or screw the other end to any part of the interior skin, frame, channel, or even the ground lug for the breaker panel.
Old 09-24-2012, 10:30 AM   #3
JackP's Avatar
1972 27' Overlander
Thanks!
Old 09-24-2012, 12:08 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Same way you grease your elbows.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
