Old 10-20-2014, 02:23 PM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
No if there is continuity on the connection use should see some reading. You will see nothing if there is an open. Use an analog meter if possible. Digital meters are not much for this test, especially with larger cables.
2004 Excursion 4x4
Old 10-20-2014, 03:45 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In your previous post with the pics. I see where the battery and converter are connected to the new fuse panel.
What I don't see is the charge line wire.
In the Bargman junction box. What color is the wire from the TV?
What color in the coach is connected to that wire.
On the fuse panel.
What is the large red wire connected to fuse # 12?
I will assume that the exterior lights work when you are plugged into the TV. Which says you have a good common/ ground connection.
Fuse #11 appears to be empty. Is this correct?
The charge line wire should be a #10 gage wire in the coach. Chances are it is black. It should be connected to the +buss at the fuse panel. It doesn't appear there is a terminal dedicated for the charge line.
In a pinch you could connect the charge line to fuse #11. You will only have 20 amp charge capability. But my guess is, the TV will only provide about 8 amps.
The other option is to tie the charge line in with the battery cable at the fuse panel. The charge line should be fused at no more than 30 amps.
Old 10-20-2014, 06:15 PM   #17
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I spent a little time after work on this problem. The trailer is not on shore power.
The trailer harness comes up through the floor under the bed. The black wire has a connector on its end to another black wire and I traced it and it goes back through the same hole in the floor under the bed. Ut doesn't route to the junction box. Under the trailer there is a plastic loom and when you split it there is a black wire. This loom runs under the trailer for a couple of feet then goes into the the bowels of the subterranean Airstream.
This group of wires comes out in the hydraulic brake controller compartment. The same plastic loom can be opened up an their is the black wire.
I don't see any cables coming up from the floor near the converter. There is a black wire leading to the fuse but its for the subwoofer. When I pull its fuse there is no power to the sub.
When I switched over to the new 12v panel I transferred one DC line at a time. While I doing all this I was running my lights the voltage dropped form 12.6 volts to 12.3 volts. My lights are all LED. I hooked up the TV and let it run and with 13.7 volts coming in the batteries still show 12.3v. I might have a second problem, either my Interstates are failing or I've got a big draw some where.
I'm beginning to suspect there is no charging line now. Could I splice in a short line to the 12v buss under the Use/Store relay switch. There are several connectors on this bus I removed the LP leak detector from it and put it on the down stream side of the relay so the LP detector is not on when the Use/Store switch is in Store.
Hopefully, Airstream will respond tomorrow.
Kelvin
Old 10-20-2014, 09:42 PM   #18
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
The trailer charge line runs through a 20 amp breaker on the battery bus bar at the front of the trailer. The position of the battery shut off switch is irrelevant. If you don't have 12v at the 7 way plug on the trailer, the breaker has tripped. This is your problem for sure. The 12v schematic that comes with your Airstream shows this bus bar and cb. I don't know if if is can be reset or not. Just call an Airstream dealer and they will tell you what you need. I am curious how these cb/fuse trips are reset.
rp709 is offline   Reply With Quote
Old 10-20-2014, 10:19 PM   #19
KJRitchie's Avatar
2008 25' Classic
I think the hydraulic brake actuator is what is making this different. The Dexter actuator manual shows the 12v lead from the TV is supposed to be connected to the actuator. Then there is the white neutral wire. The blue wire from the brake controller of the TV. Finally the wire from the break away switch, 4 wires total. If the break away pin is pull the actuator gets power via that device but for normal braking the actuator gets power from only the TV right now. Should I cut the 12v wire and then connect the two ends to the 12v bus next to the Use/Store relay? Will the actuator draw any power when the trailer is not connected to the TV?
Kelvin
Old 10-20-2014, 10:43 PM   #20
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Seems like a cigarette lighter digital volt meter plugged into any of the cigarette lighter plugs in the trailer would show you pretty quick if you are getting truck voltage in the trailer. Can't remember where I got mine, Wal-Mart or Radio Shack. Doesn't everyone have one plugged in to monitor the trailer battery voltage at night?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-21-2014, 08:12 AM   #21
KJRitchie's Avatar
2008 25' Classic
I've got one of those plugged into the TV outlet in the bedroom. It doesn't move off the current voltage when the TV is connected and running which confirms my statement above the 12v lead of the trailer harness in not at all connected to the trailer 12v system, only the Dexter brake controller. I found my 12v plugin meter was inaccurate compared to my voltmeter so I took it apart and found a small dial and was able to adjust the voltage reading to match my voltmeter.
My next step is to understand the 12v bus next the Use/Store relay. It has power to it when the Use/Store relay is in Store mode so its always connected to the two batteries.
My question about the buss is there an input side and an output side? There are several connections to this bus. As above, one of them was the LP detector, connected last in the line of post, far right. This allows the LP detector to have power when the Use/Store switch is on Store. The LP detector has its own fuse.
The youTube video above, the technician points to the first pole looking left to right on that buss and indicates it is from the 12v lead of the tow vehicle harness.
There is a junction box to the left of this buss. I don't remember seeing any wires running from that box to the buss.
I may disconnect the first lead on the 12v buss and see if power is lost to the buss.
I guess my question is if I connect the 12v trailer harness lead and the brake controlle 12v line to the same lead will this work. With it connected this way and with the trailer disconnected from the tow vehcile and the trailer not on shore power will the Dexter controller still draw power in run down the batteries or is in deactivated because there is no signal from the brake controller in the TV.
For electric brakes they don't activate when the trailer is disconnected so why should the Dexter hydaulic actuator.
I'm I one the right track?
Kelvin
Old 10-21-2014, 02:38 PM   #22
KJRitchie's Avatar
2008 25' Classic
Dexter Actuator Wiring Diagram
Attached is the wiring diagram for hooking up the Dexter actuator. Looking at the black wire from the trailer plug I notice there is a connection to the breakaway battery. In our case that's the Airstream batteries. The way my Dexter is connected, the black wire from the trailer plug goes directly to the Dexter black wire. There is no black wire from the battery + connected to the trailer plug black.
Kelvin
Old 10-21-2014, 04:06 PM   #23
dznf0g's Avatar
Oswego , Illinois
The schematic is a crude one. See that it shows both the AS battery AND the charge line connected to the actuator? In the real world, if they just hooked your umbilical black wire to the actuator and ended it there, you get no batt charge. There needs to be another wire from the charge line to your positive buss in the AS electrical center.
-Rich-
Old 10-21-2014, 04:21 PM   #24
dznf0g's Avatar
Oswego , Illinois
Kelvin, I am going from memory here, as my baby is down for her winter nap at the storage yard. IIRC the circuit goes like this, assuming your '08 25er is electrically like my '07 30er. The entire umbilical comes through the floor, in tact, and attaches in a black positive junction block box at the rear of the wooden electrical center. From there one wire off the charge line umbilical terminal, goes to the breaker block on the right side of the electrical center. From there, two wires are split off the breaker. One goes to the silver positive Buss and that is where the batts get their TV charge. The other goes back outside to the actuator.
I believe your installers cut into the umbilical and fed the charge line directly to the actuator, breaking the circuit to the black positive block, and ultimately to the batts. Not only will you get no charge, but now there is an unconnected wire which can back feed 12V to, potentially, chassis ground. And because, I believe the breakers are directional, they will not protect that potential short circuit.
You need to trace that charge line circuit back from the breaker block. BTW, ALL of this takes place UPSTREAM from the store switch and 12V fuse panel. (which contain no fuses in the classics...but are also breakers)
-Rich-
Old 10-21-2014, 04:27 PM   #25
dznf0g's Avatar
Oswego , Illinois
Hopefully I get this right.
Positive junction box is black box at top of pic
Positive breaker "buss" is on the right with the fat red converter wires attached
-Rich-
Old 10-21-2014, 06:41 PM   #26
KJRitchie's Avatar
2008 25' Classic
Here is the photo of the relay with the 12v bus below the relay. The right side of the relay is towards the trailer's 12v system so when you turn off the Use/Store switch it shuts everything down. I connected the LP leak detector to that right hand post. The 12v bus below is active whenever the batteries are online. They are unaffected by the Use/Store switch.
The black 12v wire from the trailer harness is not connected to the 12v bus. Another wire is connected to it via a butt connector and that wire goes back down the same hole the trailer/TV connector cable came up. It appears to terminate at the Dexter actuator 12v wire. Other wires go back down the hole, several orange wires a blue wire.
The last photo shows where the trailer/TV harness enters under the front bed and what wires come back out. The black plastic loom is opened up to show the wires. Notice there is a black wire which appears to be the wire from the 12v trailer harness wire. The black loom goes towards the rear under the trailer.
Still no word from Airstream.
Kelvin
Name:	Airstream Relay.jpg
ID:	224867   Click image for larger version
Name:	Airstream Relay (1).jpg
Old 10-22-2014, 08:55 AM   #27
KJRitchie's Avatar
2008 25' Classic
One of the troubleshooting steps in the Dexter manual is to connect the white wire of the actuator to the negative of the battery and the black to the postive. The result should be the motor should NOT run.
So I will cut the direct connection of the 12v wire and attach them to the 12v buss shown above. This should allow my TV to charge my battery and the actuator should work normall when the trailer is plugged into the TV.
Kelvin
Old 10-22-2014, 06:07 PM   #28
KJRitchie's Avatar
2008 25' Classic
Tonight, I cut the 12v cable and attached each end to the 12v bus. The tow vehicle now is charging the Airstream batteries. I see over 13v now on my voltmeter with the TV hook up and running. The Dexter actuator works as normal.
I attached the 12v lead to the left side of the bus on the same pole as the battery cable and the brake actuator at the other end of the bus. The yellow crimp on connectors are the cables.
I wonder why the dealer didn't do this when they swapped out the Actibrake.
Kelvin
Name:	Airstream Trailer Charge Fix.jpg
Trailer Battery doesn't stay charged morrowtimber Batteries, Univolts, Converters & Inverters 12 03-20-2011 10:53 AM
Battery Charged but Electric Items Only Working When Plugged in..help?!?!. ericwarren Our Community 12 05-07-2009 08:24 AM
Battery's gurgling while being charged? Kistler Batteries, Univolts, Converters & Inverters 4 11-16-2004 11:05 AM
Can't get batteries charged -- why not? neil.ervin Batteries, Univolts, Converters & Inverters 23 11-14-2004 07:24 PM
Electrically Charged Trailer - Help! Joe Z Electrical - Systems, Generators, Batteries & Solar 40 10-12-2004 11:04 AM
