Old 04-05-2010, 10:01 AM   #1
1972 31' Sovereign
rodanthe , North Carolina
how to replace converter?
Am a new owner of a fixer upper .. came with a new converter in a box. Looks different, no glass fuses and all. What do I need to know? I am not an electrician but have basic knowledge and can follow instructions pretty well for a girl
The new one is from WFCO
fridder13 is offline   Reply With Quote
Old 04-05-2010, 10:31 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I assume the converter came with an AC line cord and plug. If so that is a direct plug into an AC socket.
On the output or DC side you should have at least 2 large diameter wires and maybe a bare copper wire tied to the chassis. If there is a bare copper wire you should find a single screw lug most likely on the bottom of the converter frame and also most likely at the opposite of the converter from the 2 battery terminals. The bare wire goes in that lug and grounds the converter.
The 2 large wires going to the batter are critical as to which one goes to which terminal.
If you have a volt meter, and with the converter plugged in, place the common probe, black, on the copper wire and touch each of the output terminals with the other probe, red. One of those terminals will show voltage, about 13 volts. Note that terminal. With a battery installed now touch each of the large wires coming from the battery. One will show voltage, about 12 volts. Now connect the terminal/wire that showed voltage together and then connect the terminal/wire that did not show voltage together. Now check the voltage on the battery. I should be as about as the converter showed when you tested it. It may be slightly low but will come upi with time. If the battery voltage is below either of the voltages you measured before connecting up the wires are backwards on the converter.
2004 Excursion 4x4
Old 04-05-2010, 11:17 AM   #3
HowieE's Avatar
Images: 12
I did not mention it but for safety sake unplug the converter while hooking up the battery wires to the converter. Not that there is a shock problem to you but the amount of current available across those wires and terminals could cause a VERY LARGE spark.
DC voltage will not shock you.
2004 Excursion 4x4
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Should I replace the converter on a new Airstream Rawn77 Batteries, Univolts, Converters & Inverters 5 10-07-2009 11:00 AM
Do I need a new converter, or what? Dave Jenkins Batteries, Univolts, Converters & Inverters 34 08-14-2009 11:00 AM
What is the best converter? jdalrymple Batteries, Univolts, Converters & Inverters 2 03-19-2008 01:42 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
