Old 02-24-2012, 09:07 AM   #1
1972 31' Sovereign
rodanthe , North Carolina
How to remove Univolt
My eyesight is not what it was and as you know the space is cramped.. How many screws am I looking for to unmount(?) the old Univolt from compartment and where am I looking for them?
fridder13 is offline   Reply With Quote
Old 02-24-2012, 09:35 AM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Fridder
Don't see to many Airstream owners from the Outer Banks. Glad to have you with us. One of my favorite campgrounds is Sands of Time in Avon.
Make sure you have plenty of light so that you can see as well as possible. I think mine had four screws securing it to the floor, but I really can't remember. The new converter will be much smaller, so it should be easier to put in than to take out the old one. Good luck.
Dan
Old 02-24-2012, 10:15 AM   #3
1974 Argosy 20
Kooskia , Idaho
They may have 4 screws or small lag bolts in the corners where the "feet" stick out. Or they may have only two, generally in the front where they were easier to install by the workers in the factory. My 20' Argosy had none... they had pulled out, the Univolt then hopped up and down, the main wiring then got under it, and then there was an occasional short, blowing a fuse. I only found the source of that nagging problem when I replaced the darn heavy monster.
Old 03-16-2012, 01:55 PM   #4
1972 31' Sovereign
Well, alright. Got snagged by a pinched nerve..am just getting back to this. HOW on earth do you reach those nuts!? I've been awkwardly turning the nearest one but it seems to be spinning. I thought maybe Dremel but the angles are so hard and that was among the things lost in Hurricane Irene. Do I need to cut away the closet wall? thanks!
Old 03-16-2012, 02:40 PM   #5
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Ours was mounted to a piece of wood, then the wood had two screws holding it to the floor. They were right out front where you could see them. The wood and univolt slid out from the little hole and the wires were just long enough to work on it in the closet.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 03-16-2012, 03:19 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would stick a pry bar under it and gently pry. It is probably held in with 1/4" lag screws. They may just pull right out of the old wood.
I was told 'Not to Join'??? Travel Bird WBCCI Forum 159 05-09-2015 05:46 AM
How do you polish the aluminum bumper ElliotA Bumpers & Bumper Storage 14 08-28-2013 09:38 AM
Blasting Off!! '54 Cruiser...Back To Life... NTRPRZ 1950 - 1958 Cruiser 25 03-10-2013 10:45 PM
How to remove screens? Olivebranch Windows & Screens 5 02-27-2012 10:28 AM
Just about to order 2012 30' Flying Cloud - What have I forgotten? Hibby Buyer Guidelines 36 02-24-2012 05:56 PM
