Old 11-22-2011, 05:52 PM   #1
1988 29' Excella
Waco , Texas
How to remove Magnetek
Disclaimer: I'm an idiot.
I've purchased an inteli-power 9260 and am ready to install it in my '88 Excella. I thought this would be easy, but removal of the Magnetek 750 is baffling me. It has three wires running into a port in the side of the unit that are confusing me. One has braided red covering, which seems to be connected through a cut off switch to the positives on the batteries. Then a similarly sized white and a small, braided black, too small to be a negetive, I think.
I can see into the Magnetek, but can't get into it without drilling out the rivets. Since I'm trying to replace the converter before Thanksgiving, I'm at a loss about what to do. Can anyone help?
crios is offline   Reply With Quote
Old 11-22-2011, 06:47 PM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Red would be your positive, white is negative, and the small wire is the ground for the chassis. I just cut the wires near the case of the old converter, and wired them to the appropriate terminals on the 9260.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-22-2011, 06:54 PM   #3
1988 29' Excella
Waco , Texas
Thanks, Skater. There is also a bare copper wire that I thought was the ground. could there be two connections to the chasis?
Old 11-22-2011, 08:25 PM   #4
1988 29' Excella
Waco , Texas
Okay, another question. I don't have enough wire after cutting to run directly to the new converter. I have 6 ga wire from Home Depot. Will that work? I'm concerned about the insulation more than the wire itself.
Old 11-23-2011, 03:02 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Okay, the bare copper wire was the chassis ground. I'm not sure what the black wire would be...I'm pretty sure I didn't have one. Where was it hooked to on the old converter?
6 gauge is enough to carry 50 amps for lengths up to 15 feet, which is probably much less than you're actually going, so that should be fine. (source)
Old 11-23-2011, 04:49 PM   #6
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Here's a couple of diagrams. Found these on another forum. The wiring may be similar to yours. It looks like the fan motor is wired across the 110v input side of the transformer if that helps you figure out the a/c side. On this model there was a relay that switched the 12v output between the battery the 12v circuits. not sure I understand that. On modern converters the 12v output is typically common for both.
ID:	145883   Click image for larger version
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
1995 Tail light housing (remove) gmshadow General Repair Forum 1 10-10-2011 01:21 PM
Remove or fix old subfloor? gronlampa Repairing/Replacing Floor &/or Frame 16 08-20-2011 08:27 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
