01-28-2014, 10:29 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
How to know when OLD fuses are done?
Aside from the obvious of something not working inside, how does one know when these old fuses are done (broke/blown) as you can't see into them.
Hittenstiehl
01-28-2014, 10:33 PM
2012 28' International
Olympia
Put an ohm meter or continuity tester across it. If you have infinite resistance the fuse is toast. (and not the tasty kind).
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
01-28-2014, 10:41 PM
1962 28' Ambassador
Mesa
Thanks Dave will give that a try. And then what are these still available or is this a mute point and should it just be changed out to modern?
Hittenstiehl
01-28-2014, 11:26 PM
1972 Argosy 26
1973 Argosy 26
Fairmont
, West Virginia
There still Available
You can still find them. Small hometown hardware, or even ebay.
01-29-2014, 01:04 AM
1982 28' Airstream 280
Port Angeles
I'm sure it was assumed but remove the fuse to check with an ohm meter. Also they can be checked in place with a test light or volt meter. With the power on there should be the same voltage present on both ends of the fuse. These fuses are also available at Home Depot and Lowes.
Cheers, Dan
~ Margaret Thatcher ~
01-29-2014, 03:49 AM
Broadway
, North Carolina
It should not go unsaid that they need to be removed before testing for continuity with an ohm meter.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
01-29-2014, 05:52 AM
2015 30' Classic
Green Cove Springs
If you do not have any of the testers. Which you should. If you have a good ear and it popped it has a sandy noise when you shake it. This is a OLD electrican way of a quick test. They are still ava. at most any big bog hardware stores. You should always have extras so pick up several when in there.
01-29-2014, 07:23 AM
1966 22' Safari
1954 22' Flying Cloud
Saline
, Michigan
While it's true about 'if it's not broke don't fix it", spend a couple bucks and replace them. Technology has improved since the 60's.
01-29-2014, 07:40 AM
1962 28' Ambassador
Mesa
Thanks everyone for your answers. Post a question late at night and have your answers early in the morning.
Hittenstiehl
01-29-2014, 07:48 AM
1974 Argosy 26
Morrill
, Nebraska
While an ohm meter will find most blown fuses. It will not find one that has slowly cooked and melted the fuse link. But left a carbon trail.
Testing a fuse under a load is a better test. While not always a convenient method.
Periodic replacement is an inexpensive option. Along with keeping the fuse clips and barrels clean. Lose connections of the wires at the fuse holder creates heat and will cause the clips to become weak.
Upgrading to the more modern type fuse holder is another option.
01-29-2014, 01:19 PM
Wise Elder
2010 30' Classic
South of the river
Those are standard 30 amp cartridge fuses, still in widespread use, and available at any home center or hardware store. They are inexpensive and reliable. If problems arise it may make sense to polish the contact surfaces on the fuse and fuseholder with some emery cloth or 400 grit sandpaper. Identical replacement fuseholders are available from Grainger and electrical distributors and some home centers.
The wires that go through the aluminum slot at the top of the picture should have some sort of protection against being cut by the aluminum.
01-29-2014, 01:29 PM
1966 22' Safari
Saline
, Michigan
Replace with glass fuses ($.25 a piece)and you'll never again wonder if they are blown or slow arced.
