Old 03-15-2016, 06:55 PM   #15
2015 30' Classic
Pleasanton , California
The selection of the disconnect switch has no bearing on the use for a Battery Tinder. The Tinder would connect directly to the batteries even when the switch is in the disconnect position. Here's an example of one that would work.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-15-2016, 07:50 PM   #16
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by beachbouy View Post
What is recommend as a good battery disconnect switch that can be used with a solar battery tinder?
Doesn't the AS have a battery disconnect switch already installed inside the door?
Mine does.
See above schematic for attaching a battery minder.
MelGoddard is offline   Reply With Quote
Old 03-15-2016, 08:34 PM   #17
2015 30' Classic
Yes, but there are still a couple of loads that do not pass through the battery disconnect switch. The automatic jack, the propane detector and the braking system come to mind. When everything is working correctly only the propane detector at 70 mA is fairly significant if you're leaving the trailer unattended and without power for an extended period or time. A manual disconnect switch directly at the battery removes all concerns.
Al, K6IV
Old 03-15-2016, 08:47 PM   #18
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Guest makes several good quality battery disconnect switches.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 03-15-2016, 08:48 PM   #19
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Mine does.
While stored without external power, a battery disconnect switch or solar charger... Dead in less than a week.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 03-15-2016, 10:52 PM   #20
2015 23' FB Flying Cloud
Redmond , Washington
The several posts above are consistent with my experience and setup:
1. The $5 disconnect switch (I bought mine at NAPA) simply disconnects your batteries from ALL possible phantom drains (brakes, LPG Detector, Powerjack, radio presets, etc.). (2) The solar panel and charger connect DIRECTLY to your battery terminal BEFORE the disconnect switch). Thus, Charging occurs AND no phantom drain occurs.
You cap can probably get by if you simply use the battery disconnect switch. But, as I am concerned about freezing temps this month after dewinterizing, I have my thermostat set to 40F. This may use battery power (if the LPG furnace come on). So I want to recharge daily with the solar panel. I do NOT disconnect the batteries in this instance because they must power the Furnace ignition and blower fan. The solar recharges the batteries the following day. This is a modest cost solution (under $170).
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 03-15-2016, 11:12 PM   #21
Photo of disconnect switch and solar BatteryMinder connections.
D2
Old 03-16-2016, 06:21 AM   #22
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
So why not simply disconnect a lead on the battery to disconnect? What does a battery minder do differently, safer, or better? I too store mine in a storage lot, but take the battery out for long term and top it off at home with a battery charger when needed.
Native143 is offline   Reply With Quote
Old 03-16-2016, 06:55 AM   #23
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
This is just my opinion, but being able to leave the batteries in the battery box, instead of taking them out and bringing them home, is less work, especially if you have to do it with any frequency. I think the battery disconnect switch is just a convenience - it's not that hard to just disconnect/connect the negative battery cable. The solar battery minder keeps them charged, and helps you avoid battery sulfation for free once you have it.
SeaLevel is online now   Reply With Quote
How to Test if Trailer Battery is Getting Charged from Tow Vehicle KJRitchie Batteries, Univolts, Converters & Inverters 27 10-22-2014 06:07 PM
Trailer Battery doesn't stay charged morrowtimber Batteries, Univolts, Converters & Inverters 12 03-20-2011 10:53 AM
Best way to keep 12V charged when not using unit kentuvman Batteries, Univolts, Converters & Inverters 7 04-26-2010 02:04 PM
Battery Charged but Electric Items Only Working When Plugged in..help?!?!. ericwarren Our Community 12 05-07-2009 08:24 AM
Battery's gurgling while being charged? Kistler Batteries, Univolts, Converters & Inverters 4 11-16-2004 11:05 AM
