Old 07-26-2014, 03:56 PM   #29
JimGolden's Avatar
1977 31' Excella 500
Get the whole panel
I changed my 34' Avion triple axle over to 50amp last year. I also used Progressive Dynamics.
Take a look at this. This is what I did. They sell a completely new panel in which you throw out ALL the old stuff and go brand new.
Ultimate All-in-One 240V, 50 Amp AC/DC Power Distribution Panel
Rather than trying to mix and match the new with the old, I just redid it all. The new unit works slick as a whistle. Their "Charge Wizard" thing really does the batteries good.
I realize it's probably too late for you now, but this is a nice solution.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 01-09-2015, 03:33 PM   #30
1971 31' Sovereign
Indian Wells , California
I know this thread is a little bit old but I'll try anyway.
I think I'm going to do this to my '71 Sovereign. I bought the Boondocker and the Parallax FB9 fuse box but I'm having a difficult time hooking up the blue wire. Somewhere on here it said to hook it up to the negative, then I saw hook it up to the positive. It's probably something simple but I would like the ammeter to work and it won't with the Parallax.
When I took the fuse panel off my Univolt IV, the grey wire fuse connector had a wire out of the backside that went deep into the Univolt somewhere. It looks like the Univolt changed in 1972 because mine is a little bit different.
So the question is:
Airline- Where did you attach the other end of the grey wire connection to? If I wired it like yours, I would have a 6" piece of wire out the back of the fuse panel?
Thanks.
CraigCA is offline   Reply With Quote
Old 01-09-2015, 04:11 PM   #31
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You need a shunt for the ammeter to work. The Univolts had such a shunt. It looks like a copper bar or plate with connection points on it 2 for the larger wire, 2 for the smaller wire.
The shunt is wired in series with either the negative or positive battery wire. Usually the negative side. The ammeter connects to the smaller screws and is polarity sensitive.
The ammeter detects the very minor voltage drop across the copper bar. Then reads it out in amps. The larger the load the greater the reading on the ammeter.
Old 01-09-2015, 04:28 PM   #32
1971 31' Sovereign
Thanks, I got the ammeter part. The problem is really the blue wire. I don't know where it's supposed to attach to on the Parallax. Positive, negative, a fuse? I attached it to a fuse this morning and it popped. No wonder because the fuse in the Parallax is a 20A and I think the blue wire needs a 40A. I can put a 40A inline fuse but I still don't know where it goes to. The service manual says it goes to the stereo, the front ceiling fan and the tow vehicle.
Here is a picture of my Univolt fuse panel without fuses, front and back. You can see on the picture of the back, there's a wire. That wire went into the guts of the Univolt. Now that I have a Boondocker, I don't know where to wire it to. Or maybe I can't use it and I get no power light?
Old 01-09-2015, 06:38 PM   #33
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Measure the voltage on the wire in question. Referenced to common/ground. It appears to be connected to the buss on the Univolt. If you read 12 or more volts, it could be used for the power on light. Turn off the converter and see if it goes to zero volts. If so, it should work for the power on light.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
New 3 stage converter install mayco Classic Motorhomes 3 05-03-2014 02:14 PM
Install new converter Echogram Batteries, Univolts, Converters & Inverters 10 05-29-2012 11:01 AM
InteliPower Converter Install Questions DPeakMD Electrical - Systems, Generators, Batteries & Solar 9 06-03-2004 09:57 PM
