Closed Thread
Old 05-22-2016, 07:26 AM   #15
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
ziggy,,
that is all good info. looking at doing 4-100 watt panels as well. Yes the convertor is the oem one and the voltage is like 13.6v.. k
was going to get a iota DLS-55 (55 Amp Power Converter w/IQ4) for batteries now and when we change to the 6v golf cart ones.
looking at a morningstar tristar 30 amp mppt mounted under the front sofa and 2 6v golf cart deals like the t-105s mounted in box behind LP tanks on a-frame.
have started changing out fluorescent light in hallways etc with LEDS. PO had changed the spot reading lights up front and in bedroom the 4 lights over bed with LED.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline
Old 05-22-2016, 12:28 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by carl2591 View Post
ziggy,,
I think you'll be happier with the Blue Sky 2512iX-HV and their iPN -PRO remote. Much easier to program, faster MPPT tracking and a full function battery monitor as well.
Way more functional with great battery and charge information.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster is offline
Old 05-23-2016, 04:19 PM   #17
carl2591's Avatar
2005 31' Classic
interesting.. is the absorption and float values adjustable for lead batteries?..
trojan recommends 14.8v for 12 volt batteries absorption and 13.6v float. In reading the 2512i info it show 14.2 v absorption rate and 13.2 float fixed rate.
Our good friend bob also recommends 14.8v min at 77. In reading info on morning star they are more adjustable in that regard.. maybe the IPN controller allows for that adjustment with the blue sky unit??
it is small and lightweight enough that for sure.
Lew Farber
541-490-6357
Carl, Raleigh NC
carl2591 is offline
Old 05-23-2016, 10:55 PM   #18
lewster's Avatar
The 2512iX-HV when coupled with the iPN-PRO remote is fully programmable for voltage set points, size of battery bank and the duration of the absorb charge. It also has a temperature sensor that will automatically adjust the charging voltage according to the ambient temperatures found at the batteries, along with an adjustable temperature compensation slope that can be programmed to specific battery requirements.
Everything is fully adjustable!
lewster is offline
Old 05-25-2016, 06:51 PM   #19
carl2591's Avatar
2005 31' Classic
so would the 2512iX-HV and iPN pro with shunt be a better combo than the ipn pro without shunt and the bogart 2025RV monitor with shunt, or not.
if i am looking at the dimension this thing is only 5.5 x 5.5 x 2.5" is that right?? bearly enough case to run the wires needed, #4s, from combiner box to controller.
I am guess you have used this before hence the recommendation for them?
Carl, Raleigh NC
carl2591 is offline
Closed Thread
'82 limited 34' tank capacities GO Bob 1982-1983 Limited 0 05-21-2006 06:47 PM
Tank Capacities wohtex Waste Systems, Tanks & Totes 6 04-15-2006 09:29 AM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 07:15 AM
Tank capacities - anybody know? drboyd 1970-79 Tradewind 3 09-05-2003 10:54 AM
Weight capacities for 25' six sleepers ? (Safari/CCD) darkStar Our Community 5 08-05-2003 11:19 AM
