Old 07-03-2017, 01:48 PM   #1
MOS
2016 28' Flying Cloud
Queensbury , New York
how to connect two 6v batteries
Going to switch the two 12v bats to two 6v bats
My 2016 AS has two sets of red/black cables coming from the trailer.
So how is this wired
MOS is offline   Reply With Quote
Old 07-04-2017, 01:02 PM   #2
2015 30' Classic
Pleasanton , California
Here's a schematic:
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 07-04-2017, 02:14 PM   #3
MOS
Originally Posted by alano View Post
Here's a schematic:
Attachment 288708
Not sure I understand this but
two reds to + one battery , two blacks to - other battery
And then ?
Old 07-04-2017, 02:21 PM   #4
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
And then ?
And then the positive on the one with the black connections to the negative on the one with the red connections.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 07-04-2017, 02:50 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
*Everything* (no matter what it is) that now goes to the + side now will go to the "RED" line in the drawing above.
*Everything* that now goes to the - side will go to the "BLACK" line in the drawing.
The only thing that will go between the two batteries is a jumper wire. Nothing else will connect to this mid point.
Old 07-04-2017, 02:54 PM   #6
Mollysdad's Avatar
Not sure why your two 12v volt batteries are not paralleled.
However, I'd recommend marking the cables with e-tape before removing. I put one red marking on battery 1 +, one white marking on battery 1 -, two red markings on battery 2 +, etc.
Your 6v batteries will need to be connected in series to obtain 12v.
that's why the - from one will go to the + of the other and then you'll be left with a single + and - to connect the load to.
Old 07-04-2017, 03:44 PM   #7
1977 31' Sovereign
2005 30' Safari
North Port , Florida
Connect + bat 1 to - bat 2 with jumper. That will create 12 volts across both batteries.
cliffcharb is offline   Reply With Quote
Old 07-04-2017, 04:03 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It's probably not that his 12V batteries are not paralleled. It's that there's a red & a black cable for the lines to the fuse block, and a red & a black cable to the inverter. On mine, there's an additional skinny pair running from the "Zamp" inlet to the batteries as well. It's a bit of a snake nest!
David
Old 07-05-2017, 04:00 AM   #9
MOS
I just don't get running a jumper cable from the + on one battery to the - on the other battery .
Sounds like trouble !
Old 07-05-2017, 04:22 AM   #10
SeaLevel's Avatar
Jupiter , Florida
Think of that as an internal connection. Now you have two 6 volt cells added together to give you 12 volts, and two external connections - one '+' and one '-.' If you turned one of the batteries around, both external connections would be the same.
Old 07-05-2017, 04:53 AM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That's helpful to think of it that way. It leads me to 2 questions though:
1) with the two 12 volts, I know taking the negative off first is the safe way to remove them at the end of the season and connecting the positive first is the safe way to put them back in at the start of the season. What would be the correct sequence for removing and reinstalling the two 6 volts wired as you suggest?
2) would any changes be required to the converter/charger or any other electronics?
Thanks!
Old 07-05-2017, 05:47 AM   #12
Gainesville , Florida
Simplified....six volts are connected in series, 12 volt are connected in parallel. Six volt......pos to neg. 12 volt.....pos to pos, neg to neg.
Old 07-05-2017, 06:42 AM   #13
SeaLevel's Avatar
Jupiter , Florida
Thanks!
1) I don't see why you couldn't follow the same sequence.
2) No. It's still 12 volts across both batteries.
I'm still using 2 12 volt batteries connected in parallel, but a lot of people have moved to using 2 6 volt batteries, which they then need to connect in series to measure 12 volts.
Parallel: Capacity (amp hours) is additive and the volts stay the same.
Series: Voltage is additive and the capacity (amp hours) stays the same.
http://www.zbattery.com/Connecting-B...es-or-Parallel
Old 07-05-2017, 07:27 AM   #14
W , New England
I'm just thinking about the "internal" connection from - to + between the 2 batteries. I guess you'd remove the negative side of the jumper and then the negative terminal, then the positive side of the jumper and then the positive terminal...?
Batteries uninstalled...can I connect shore power safely? lovetokite Electrical - Systems, Generators, Batteries & Solar 9 05-28-2017 07:05 AM
Connect two TVs to winegard antenna Chpstar1 2005 and newer - Bambi all models 4 09-25-2013 10:42 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
