Old 07-05-2017, 08:33 AM   #15
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Originally Posted by SteveSueMac View Post
I'm just thinking about the "internal" connection from - to + between the 2 batteries. I guess you'd remove the negative side of the jumper and then the negative terminal, then the positive side of the jumper and then the positive terminal...?
I would just leave that one connected. It's the "external" connections that would remove the load.
Or you could put a battery switch on the positive side of the "external" connections, and just use that to disconnect for storage.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 07-05-2017, 09:28 AM   #16
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The "easy" place to put the disconnect switch on a pair of 6V batteries is in the jumper between the batteries.
Old 07-05-2017, 10:25 AM   #17
Mollysdad's Avatar
The reason to disconnect the - first and connect last is so if you hit the frame (or metal) accidentally with your wrench it won't throw a big spark.
I'm going to install one of these to kill all power from the batteries when stored.
Mollysdad is online now   Reply With Quote
Old 07-05-2017, 12:51 PM   #18
2015 27' FB International
Erie , Colorado
2 6 volt batteries
Here is a picture of my 6 volt battery setup. One point of note is that your current battery box may not be deep enough to hold the 6 volt batteries. We swapped out the 12v batteries to 6v when we bought our trailer and the dealer modified the battery box by cutting out the bottom of the box and welding 1 1/2in angle iron to the bottom of the box.
Rockhound100 is offline   Reply With Quote
Old 07-05-2017, 01:48 PM   #19
2013 Interstate Coach
La Mesa , California
If it help you to understand battery voltage a little better...Look at your maglite flashlight or any multi battery flaslight for that matter. The batteries are loaded up with all the + facing into the the tube...so the - end of the first battery is in contact with the + end of the second battery and so on....the jumper cable is JUST to connect the 2 batteries BECAUSE you can not physically attach the terminals of the batteries as you do with the flashlight. This is called a SERIES connection and thus the total voltage across the terminal is 6+6= 12VOLTS.
AirRiggie is offline   Reply With Quote
Old 07-05-2017, 01:54 PM   #20
Half a Rivet Short
Hi
Or burn a big chunk out of the frame where the wrench hits ....
Old 07-05-2017, 01:59 PM   #21
Half a Rivet Short
Originally Posted by MOS View Post
I just don't get running a jumper cable from the + on one battery to the - on the other battery .
Sounds like trouble !
Hi
The formal answer to "why" is that if you don't make that connection, no current can flow. You need current to do anything useful.
Hopefully by now we have answered this? If not please chime in and we'll all try to come up with more details or analogies.
Old 07-05-2017, 02:49 PM   #22
2007 22' International CCD
how to connect two 6v batteries
Just to be real clear: Jumping + terminal on one battery to - terminal on the other ONLY applies to connecting two 6 volt batteries in SERIES to get 12 volts total.
If you are not solidly sure of what you are doing, please get a professional to help. Batteries can cause some interesting damage if mishandled. (Interesting in the 'Spockian' sense, if you get my drift...)
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 07-05-2017, 09:00 PM   #23
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by alano View Post
Here's a schematic:
Attachment 288708
That's one set of cables.
What about the other set???>
MelGoddard is offline   Reply With Quote
Old 07-05-2017, 09:15 PM   #24
SeaLevel's Avatar
Jupiter , Florida
They would need to connect just like the first set, so that they would get the full 12 volts from the batteries. Both positives (red) together, and both negatives (black) together.
Old 07-05-2017, 09:35 PM   #25
Half a Rivet Short
Hi
Ok, go to Lowes, get a can of Orange spray paint and a can of blue spray paint.
Take the orange paint and spray every single wire that is connected to any of the + posts on the 12V setup orange. Do a real good job so the paint does not come off.
Take the blue paint and spray every single wire that is connected to any of the - posts on the 12V setup blue. Again get them all well painted.
Now pull all the wires off the posts on the 12V setup. Any wire with both ends off, throw away. Any wire with two disconnected ends on it, cut off the "extra" end and throw the extra end away.
Remove the 12V batteries and send them off to recycle land.
Drop the 6V batteries into the battery box. Hook the two 6V batteries up as shown in the earlier schematic.
Hook every wire with orange spray paint on it to the point on the schematic labeled red. Depending on your trailer that may be two wires, it may be a dozen wires.
Hook every single wire with blue spray paint on it to the point on the schematic labeled black. Again, depending on your trailer that may be one wire it may be three or four.
If that's not clear enough, head over to the local garage and pay them $10 to hook it all up for you. It should take them less than 10 minutes.
Old 07-06-2017, 07:04 PM   #26
connection
If you are still using the original cable provided by Airstream, i would suggest replacing your battery cables with 1/0 or bigger especially if you are using an inverter that is greater than 1000watts. My rig was originally supplied with a 4AWG cable so they double up on the cable as shown in the diagram on the right. You can also use this method using 2 cables per connection if you have the 4AWG cables.
Old 07-06-2017, 07:08 PM   #27
Half a Rivet Short
Hi
If you have a long run and a big inverter, go to at least 6/0 ...
(it all depends on how big that is and how long the run ...)
Batteries uninstalled...can I connect shore power safely? lovetokite Electrical - Systems, Generators, Batteries & Solar 9 05-28-2017 08:05 AM
Connect two TVs to winegard antenna Chpstar1 2005 and newer - Bambi all models 4 09-25-2013 11:42 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 08:18 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-23-2010 12:50 AM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 07:06 PM
